Thread: 2006 GXP spray?
Results 1 to 20 of 39
  1. #1 2006 GXP spray?
    SE Level Member 06grandprixgxp's Avatar
    Aug 2011
    Hinesville GA
    Im gonna spray my car here shortly but idk what plugs to get or anything i know i can only do a 100 shot so anything else i need 2 kno
  2. #2 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    i also have a diblew custom tune
  3. #3 Re: 2006 GXP spray?
    Kansas
    Diblew = Diablo?
  4. #4 Re: 2006 GXP spray?
    utah
    i know alot of people who spray there gxps...what kit are you going with?
  5. #5 Re: 2006 GXP spray?
    Omaha, NE
    Pull timing and have some fun.
  6. #6 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    Quote Originally Posted by NegativeOne13 View Post
    Diblew = Diablo?
    its a diablo sport that my buddy 06montess from gmls4.com or ls1tech.com custom tunes
  7. #7 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    Quote Originally Posted by boostedcompg View Post
    its a nx universal kit... is there a plate kit for my car? if so do you have a link?
  8. #8 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    what plugs do you reccomend? also is there anyting specific i need to ask my tuner?
  9. #9 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
  10. #10 Re: 2006 GXP spray?
    utah
    id go with a wet kit (hopefully you have) just for the kick in the pants factor. as for a plate you can mount your nozzle several different ways. if you have a cai intakes just tap into it (post maf) and use some apoxy to seal the nozzle into the hole youve tapped
  11. #11 Re: 2006 GXP spray?
    Omaha, NE
    Quote Originally Posted by 06grandprixgxp View Post
    Whatever temp your current mods need with a bit smaller of a gap.
  12. #12 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    i have a stock cai i cant find a plate kit for the car... it is a wet kit
    diablew custom tune
  13. #13 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    i only have a diablew tune so as far as plugs what would you reccomend?
    diablew custom tune
  14. #14 Re: 2006 GXP spray?
    Omaha, NE
    Tap the nozzle through your MAF.
    I would say stock or one range colder should be good.
  15. #15 Re: 2006 GXP spray?
    utah
    one range colder and again just tap into the tubing for the intake. closer to the intake manifold the better
  16. #16 Re: 2006 GXP spray?
    Colder plugs are better for spray...less chance of detonation...and a close gap...
    You can always just cut a little hole in the factory rubber intake to mount the nozzle...that way it looks all stock and sh1t.
    But I'd also do exhaust mods before spraying it...Nitrous cars like to breathe maino.
  17. #17 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    it will be fine the way it is though yes?
    diablew custom tune
  18. #18 Re: 2006 GXP spray?
    Omaha, NE
    Depends on the size of the shot
  19. #19 Re: 2006 GXP spray?
    GT Level Member Hawkins04's Avatar
    Ga
    I wouldn't go any bigger than a 100 wet shot with the stock motor and I would recommend one range colder plug as thats what I have read for lews posts on tuned cars
    Wouldn't You Like To Know
  20. #20 Re: 2006 GXP spray?
    Aug 2011
    Hinesville GA
    ive been told the most i can do is a 100 shot so thats all im doing
    diablew custom tune
  1. Running spray on my setup?
    By whiney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 12:36 PM
  2. textured spray paint
    By gtp239 in forum Visual/Body Modifications
    Last Post: 01-02-2011, 11:37 AM
  3. Rustolium Tint Spray
    By joshsGT in forum Visual/Body Modifications
    Last Post: 06-17-2010, 01:49 PM
  4. those of you who spray....
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 12-21-2009, 07:27 AM
  5. Intercooler Spray Bar Kit...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 12:18 AM
