Thread: Engine whine!! 2008 grandprix gxp 5.3 v8
Results 1 to 15 of 15
  1. #1 Engine whine!! 2008 grandprix gxp 5.3 v8
    Apr 2011
    Maryland
    Hi pontiac family. I put my car in the shop 4 a whine noise near the power steering pump some where in that area. When i accelerate it almost sounds like i have a turbo, our a super charge. The sound is not as loud when my car is idling but its there. So my mechanic, told me that it was my harmonic balancer, and that he suggested my power steering pump, as well as my serpentine belt need to be changed. Well after doing all of the 3 things, the sound is still there!!!!! He told me that he had add in a adjective in the power steering fluid because he did not no if it was that our not!!!!!
    Any suggestions our insight please??????????????
  2. #2 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Jul 2008
    Tampa, FL
    could be something in the trans? does it happen in reverse at all?
  3. #3 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Apr 2011
    Maryland
    yeah it do. its constant!! i have 75,000 miles on my vehicle
  4. #4 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Apr 2011
    Maryland
    But the noise is coming somewhere near the pulleys, near the power steering pump!!! Im lost n i think my mechanic is 2!!!!!
  5. #5 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    Its just your cars way of saying it does not appreciate being born with front wheel drive and a 4 spd.
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  6. #6 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    SE Level Member Hoss Lanier's Avatar
    Apr 2011
    Calhoun, La.
    powersteering pump idler pulley. I just bought my car ansd have replaced it already.
  7. #7 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Midland MI
    Quote Originally Posted by tonio301 View Post
    Trust me on this right now. My GXP did the same thing. IT's the idler pulley directly after the power steering pump. Put a stealthascope thing on it and you can hear it loud and clear. Replace the pulley and then its silent.
    I actually replaced my pump before I figured out it was just the pulley!
  8. #8 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    SE Level Member ryanm's Avatar
    brampton
    i think i might have the same problem, but it only happens when i'm in drive. did this only happen in drive when you had this problem?? Only when i give the car gas it whines
  9. #9 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    First off...just check the fluid...see if there is even any in there. Next I'd try the water pump...they tend to squeal, or the PCV Valve...had those issues before. Or, if it is a pulley of sorts...spray some WD40 on all the pulleys and see if the noise goes away...do it 1 by 1...that way if it stops you've tracked the noise down.
  10. #10 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    brampton
    After reading your post, i went outside checked the fluids they are all good. then i turned the car on and listened for the noise i couldnt pin point the problem so i got a can of silcone lubrication spray and started with the idler pulley then power steering pulley with the car on, within a few minutes the sound was gone! this helped me out alot thanks for your help!
  11. #11 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Always check the free and simple things first...best rule of thumb!
  12. #12 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    Is lubricating the pulleys a permanent thing? Or will the noise soon return?
  13. #13 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Quote Originally Posted by Remnant King View Post
    Most of the time it'll fade again...it is just a bandaid. Granted...I WD40'd the crap out of all the pulleys on my old Buick and drove it for 2 years and they only sqeaked again when they were cold out.
    I'd isolate the pulley and replace it for sure when the funds are available...and with metal ones...since GM likes to put plastic ones on there for some odd ass reason.
  14. #14 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Apr 2011
    Maryland
    I appreciate all the sapport guys, and YES!!! It was the power steering PULLEY!!! NOW MY ENGINE IN NICE AND QUIET!!!!!!!!!
  15. #15 Re: Engine whine!! 2008 grandprix gxp 5.3 v8
    Glad you got it fixed broske.
  1. 2007 GXP Engine Whine?
    By WkDcLwNz in forum 5.3L V8 (LS4)
    Last Post: 05-05-2011, 05:49 PM
  2. 2008 Grandprix 56K Miles-- Wheel Bearings replacement.
    By magickid in forum Tires & Wheels
    Last Post: 04-09-2011, 07:25 PM
  3. engine whine
    By Nittles in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-28-2010, 07:25 AM
  4. Fuel pump whine when engine gets hot
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2009, 02:23 PM
  5. Engine Whine?
    By Asinity in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2008, 02:13 PM
