Thread: exhaust/ and mpg
Results 1 to 9 of 9
  1. #1 exhaust/ and mpg
    Jun 2010
    ohio
    my mufflers are rusting out and having holes in them causing my car to be louder, I use to like the loudness now not so much, and was wondering if by putting the mufflers from a gt on my gxp if it will quiet it down or if thats even possible. also is there something I could do to increase my gas mileage it's not doing so good and I don't beat on my car a lot and I drive 14 miles one way to work everyday.. don't get why the mileage sucks, unless it's from the hole in muffler and the fact my back tires are directional and the front aren't? could that have an affect on anything other then the fact the back ones hum
  2. #2 Re: exhaust/ and mpg
    Florida
    You can put pretty much any muffler on your car, as long as the inlets are the same, and you weld them up. A shop can do that for dirt cheap.
    No idea how many miles are on the car, but when gas mileage sucks, its a good idea to do a good tune-up.
    New:
    Air-filter
    Fuel-Filter
    Oil Filter
    Oil Change
    Spark Plugs
    Plug wires (if theres any phyiscal damage)
    and clean out MAF.
    If the rear tires are directional, and they are facing the wrong way...that's no good...you need to get them turned around.
    But as long as the tires are all inflated to the recommended pressure (typically 30-32psi) then that wont be killing the gas mileage.
    Do a quick little tune up, and your mpg should jump up a bit.
  3. #3 Re: exhaust/ and mpg
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    You can increase your gas mileage on your car with the K&N intake. I used to get 15.3 in city and now I get 19.5 all day every day, it has more than paid for itself.
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  4. #4 Re: exhaust/ and mpg
    Claiming over 4 mpg's from an intake is crazy on these cars...you probably had a very dirty air filter as well.
  5. #5 Re: exhaust/ and mpg
    South
    I just know what I was getting compared to what I have been getting since the swap, nothing else has been changed on the car.....I dont know what caused it to be better but I know what GXP's average in the city(15-16) stock and now mine has been at 19.5 for the longest time after the intake. If that is what made it better I dont know but its been better since then.
  6. #6 Re: exhaust/ and mpg
    Apr 2011
    Michigan
    do you run premium fuel or regular, also try topping off the tank and adding lucas oil fuel system cleaner i drop one in every 3000 miles or so and it really helps
    Profession: Car Audio and Electronics Sales
    Experience: 10+ years
    Rides: 07 Grand Prix GXP/08 G6 v6/ 78 Camaro
  7. #7 Re: exhaust/ and mpg
    Jun 2010
    ohio
    I now run regular with gas prices being so high but I use to only put in premium but it was just getting really expensive and with this being the only vehicle I have it started to break me.. but I am going to try the fuel cleaner thanks
  8. #8 Re: exhaust/ and mpg
    Here goes this again...
    LS motors like higher octane...its an all aluminum V8...they run better on a higher octane, proven. You saying you can't afford the expensive gas is rediculous. Premium is no more than a quarter a gallon more than low grade 87...so every fill up...that's what...an extra 5 bucks?
    Like stated before...new plugs/wires/air filter/o2's...these cars are just like any other car...they need to be maintained and if you let it go...it'll get crap MPG's...stuff will start breaking...etc.
  9. #9 Re: exhaust/ and mpg
    SE Level Member GMGUY's Avatar
    Dec 2010
    West Jordan Utah
    All cars like Premium...Ls motors computer programs will adjust to lower oct after the SRT codes read in the computer. The AFMs and timing is adjusted to compensate for it.. I run 85 oct( thats my states low grade) and I get 19 to 21 in the city.. and 32 on hwy... only time I run 91 or higer is when I engage my program and run Nos...Also our plugs (stock) are rated for 100k before the change...
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. Looking for exhaust
    By 02gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2009, 02:47 PM
  3. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum General Tech Discussion
    Last Post: 03-18-2009, 02:47 AM
  4. VRS EXHAUST- Mandrel Exhaust kit.
    By Lion29GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2009, 02:43 AM
