Thread: Evap system leak in '06 GXP
Results 1 to 16 of 16
  1. #1 Evap system leak in '06 GXP
    indiana
    My check engine light and Check Gas Cap warning came on last week. Diagnostic said it was a 'Gross Leak' in the evap system. The gas cap looks fine. How much should I expect to pay for a fix on this and what are the consequences of not fixing it right away?
  2. #2 Re: Evap system leak in '06 GXP
    EVAP canisters (at least for the GP or my Cobalt) were less than 40 bucks...and you just unhook the old one and toss the new one on and clear the code.
  3. #3 Re: Evap system leak in '06 GXP
    SE Level Member gtx3800's Avatar
    Gillespie, IL
    My 06' GXP also has a 'Large Leak' in the evap system. Smoked the tank, it didn't leak. opened and closed the valve with the tech2 and it seemed to funtion properly. Closed the valve and ran the car while watching the tank pressure on tech2, it didn't come off 0. Pressure sensor was the culprit. Looks similar to a MAP sensor. It's not an item you can order separately from the pump. Kinda like the in tank fuel filter.. f*ckers
    THERE IS NO REPLACEMENT FOR DISPLACEMENT!
  4. #4 Re: Evap system leak in '06 GXP
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    This seems like a common problem as I'm having the same exact issue..
    Fcuking GXP's.
  5. #5 Re: Evap system leak in '06 GXP
    Apr 2011
    Michigan
    ive got the same code too, car had a quick fill cap on it, put a normal cap and was fine for a day or 2, taking it to the dealer on wednesday, i just got the car too.. not happy
    Profession: Car Audio and Electronics Sales
    Experience: 10+ years
    Rides: 07 Grand Prix GXP/08 G6 v6/ 78 Camaro
  6. #6 Re: Evap system leak in '06 GXP
    pa
    same problem here
  7. #7 Re: Evap system leak in '06 GXP
    pa
    ACDELCO Part # 16238399 fuel tank pressure sensor
  8. #8 Re: Evap system leak in '06 GXP
    Iowa
    if it is a P0446 most likely its the vent valve if you do any gravel driving. Its behind the left rear tire inside the rear bumper cover
  9. #9 Re: Evap system leak in '06 GXP
    SE Level Member TML529's Avatar
    May 2008
    Chicago
    Is anyone experiencing the strong odor of gas inside the cabin after a fill up?
  10. #10 Re: Evap system leak in '06 GXP
    Quote Originally Posted by TML529 View Post
    That sounds like an exhaust leak moreso EVAP IMO.
  11. #11 Re: Evap system leak in '06 GXP
    chicago
    I'm throwing PO455 code, which sounds similiar to this situation. At first it was a small leak and I replaced the gas cap and it went away for about a week. It came back as a Large Leak. Not sure what the fix is. Thanks
  12. #12 Re: Evap system leak in '06 GXP
    pa
    the parts guy at the local chevy dealership suggested changing the evap cannister. i changed it psoblem solved.
  13. #13 Re: Evap system leak in '06 GXP
    chicago
    will do. Thanks a lot.
  14. #14 Re: Evap system leak in '06 GXP
    Aug 2011
    TN
    I have a 97 grand prix 3.8 That build a whole lot of pressure in the fuel tank speacially on hot days. I replaced the, fuel cap. evap silanoid, evap valve, canister. When I open the gas cap I still get a lot of pressure blowing out of the tank.
  15. #15 Re: Evap system leak in '06 GXP
    Sep 2011
    fyffe
    When taking off the evap canister how do you remove the big vacuum hose? I tried pulling and twisting and it doesn't want to budge. I'm afraid of breaking it. Do I need to get rough with it or what?
  16. #16 Re: Evap system leak in '06 GXP
    pa
    as i recall it had a spring hose clamp.
  1. evap leak need help
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 08:58 PM
  2. Deleting EVAP System
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 01:48 PM
  3. evap and pcv
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2010, 04:42 PM
  4. Problem with the EVAP system
    By victorrleo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 06:10 AM
  5. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
