Thread: cai or ram air for the GXP
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 97
  1. #1 cai or ram air for the GXP
    Baltimore
    i have doing some research on new a intake for my GXP and i can't make up my mind on what i want. i talking to other ls4 owners and they say that CAI's take away torque and you will gain HP, but others say that ram air adds torque but takes away HP .so i don't know what to believe, please help me out guys??
    p.s.
    is there any good Ram air intake's out there? i can buy and who make them?
  2. #2 Re: cai or ram air for the GXP
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    i couldnt tell that it really took away any torque but it definitely got a 4 mpg consistent gas mileage increase.
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  3. #3 Re: cai or ram air for the GXP
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Well if your willing to cut up a head light you could have a cold ram air intake.
  4. #4 Re: cai or ram air for the GXP
    Baltimore
    oh thanks guys, i'm going to get a k&n CAI in a few weeks.
  5. #5 Re: cai or ram air for the GXP
    Banned
    Mansfield, Ohio
    Quote Originally Posted by 06blgxplover View Post
    No such thing and why?
  6. #6 Re: cai or ram air for the GXP
    Baltimore
    Quote Originally Posted by cleangtp View Post
    ummmmmm hear it is. 63-3059 - K&N 63 Series Aircharger Kits, Performance Intake Kit
  7. #7 Re: cai or ram air for the GXP
    Banned
    Mansfield, Ohio
    Yeah it's an intake but not a cold air intake. Not sealed off from the rest of the engine. It's probably a good system but you can do way better for way cheaper.
  8. #8 Re: cai or ram air for the GXP
    South
    No you cant IMO, thats the exact one I got and after having it I couldnt have gone with any thing else. Its very high quality and makes your car have a very loud growl from the front, but like I said it pays for itself in a couple of months with the gas savings....I think its a great product, also that is HP gain to the wheels and not to the crank.
  9. #9 Re: cai or ram air for the GXP
    Banned
    Mansfield, Ohio
    Quote Originally Posted by BeastlyGroceryGetter View Post
    Dude it's almost 300 bucks, not closed off to engine heat, creates more knock retard. You're paying almost 300 bucks for a intake tube and filter. You can pay 40 bucks, buy k&n filter, go to home depot, buy 4 inch abs tubing cut to the dimension you need. Buy roof flashing and close it off to the heat or run open cone. The reason the gas mileage is better is because it sucks in hot air. If you live in a winter climate have you ever wondered why you use more fuel in the winter? Cool dense air near ambient temps will always make more power.
  10. #10 Re: cai or ram air for the GXP
    South
    Actually I don't get any worse gas mileage in colder temps than in hotter as far as I know, going to work would let me know that and i spend the same on gas each week either way, as far as the "custom" intake..... Idk I would much rather have the higher quality prebuilt intake system with the heat shield that does easily block the heat(u could see that if u seen it installed) than I would the other intake that could potientally damage or throw off the settings but idk I know nothing about cars, I just go for the easier and safer route when it comes to my(way too big of) investment.
  11. #11 Re: cai or ram air for the GXP
    Baltimore
    good points man! for me i like K&n products and i'm not that much of a handy man when it come to those things, like BGG said i would rather get one that premade for my car. now thats not saying i have not looked for other CAI's, the problem is that there isn't any other CAI out there right now for my V8 .
  12. #12 Re: cai or ram air for the GXP
    Jan 2009
    Farmington Hills, MI
    The reason the K&N gets better mileage is because it is less of a restriction than a Delco filter, but the tradeoff is that the K&N is only about half as effective at filtering out particulate matter. It's a flow difference, and if you see more than 0.5mpg improvement some of that is because you changed the way the MAF reads and leaned out the fuel mixture. Beastly, it may also be that you are spending more time in DOD because you bumped up the power a bit. 4mpg is about in the middle of the range I've seen DOD help (from about 2mpg at 90 to 12mpg at 50).
    You use more gas in the winter because of a lot of reasons. For emissions reasons, gas is reformulated in the winter with additives to keep gas from freezing and help cold starts. This lowers the amount of energy per gallon of gas. Also, it takes more gas to push through snow than it does to roll on pavement. There's actually several more reasons why mileage is worse in the winter that are related to temperature, but have nothing to do with the temperature of air going into the engine directly. I'm not arguing that colder air doesn't make more power, but that's because of better cylinder filling and better thermal efficiency. The improved thermal efficiency helps mileage a bit, but in the winter it is more than offset by the changes to gas.
    My setup is from Cold Air Inductions, and does a decent job of sealing out hot engine air. It uses a K&N filter but is a little cheaper.
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  13. #13 Re: cai or ram air for the GXP
    Some people just want the ease of it...and the warranty...or the name brand...or just don't posses the raw mechanical skills you do.
  14. #14 Re: cai or ram air for the GXP
    Baltimore
    dude calm down
  15. #15 Re: cai or ram air for the GXP
    South
    yea i couldnt find the dip stick much less make an intake, i am a gun mechanic not a car mechanic
  16. #16 Re: cai or ram air for the GXP
    Banned
    Mansfield, Ohio
    Here's my intake, quite easy to do, very simple. Cost me $66 out the door with a $10 off coupon from advance. It's 4 inch tubing with a 45 degree bend, I tried the 22.5 degree bend but the filter was to big and was hitting I believe the cruise control. I bought one 3.5 to 4in coupler, bought a 7/8's holesaw bit for IAT, came with the grommet. K&N filter 4x9 inch very pleased. I actually saw on the butt dyno you can def feel the difference. Supercharger screams like a baby. I also had a old 45 degree elbow and since my car is a 98gtp I already had the triangle duct where the guys use the roof flashing. I attatched the 45 degree bend on the inside of the fenderwell to duct cold air right to the tip of the filter. Cell phone pic sorry bout the quality.
    Cell phone pic, sorry bout the quality.
  17. #17 Re: cai or ram air for the GXP
    Baltimore
    why on earth is that people who have GTs and GTPs (that have V6s) have the need to come on to a V8 forum and tell us what to do,to our beast?
  18. #18 Re: cai or ram air for the GXP
    New Mexico
    For my GXP, I did the K&N for a couple of reasons:
    1. I work 10-12 hour a day 5 days a week, have 2 kids and just don't have time to design my own intake.
    2. I make enough money that while I don't like spending $300, I can afford it if I save money for a couple of paychecks.
    3. If you make it yourself, you do not get the help from K&N's lawyers if your dealer states that your intake destroyed the MAF, Cat, cam, piston's, etc. K&N's intake even has a handy 1-800 number to call if the stealership gives you hassle. I have actually used this service when a VW tech said that my K&N intake cause my cam to fail in my turbo VW, the lawyers talked to the tech and voila...warranty work with no more hassle.
    4. The shield, while not blocking all heat, appears to do a fairly good job as after an hour of driving I can touch the clamp on the filter and it doesn't burn me, where as the clamp on the MAF housing does burn the hand...not one of my smarter moments.
    5. Since there is very little support for the GXP, I have to believe that the R&D that K&N does is a little better than Joe fixit who uses PVC tubing and roof flashing to make an intake. Not banging on those that do it, more power to ya, but I am not an engineer, so I will leave the engineering to the people who know what they are doing. Just a change in materials, I think, can change the flow characteristics of the intake...but once again I am not an engineer, so that is just a guess.
  19. #19 Re: cai or ram air for the GXP
    because an intake is an intake and it will have the same effect on nearly all cars. granted you might gain more power due to the design of your factory intake, the theory is all the same. the K&N is highly overpriced for what it is and we are just giving examples of how to save yourself some money and still have something that is very easy to install.
  20. #20 Re: cai or ram air for the GXP
    Think your car is better or something? Only thing you've got is a better exhaust note.
air, cai, gxp, ram
