Thread: 2008 GXP. Where to start?
Results 1 to 14 of 14
elpasogxplover 2008 GXP. Where to start? 01-11-2010, 10:25 PM
kfish Re: 2008 GXP. Where to start? 01-11-2010, 10:26 PM
elpasogxplover Re: 2008 GXP. Where to start? 01-11-2010, 10:31 PM
kfish Re: 2008 GXP. Where to start? 01-11-2010, 10:32 PM
elpasogxplover Re: 2008 GXP. Where to start? 01-11-2010, 10:45 PM
blueguy Re: 2008 GXP. Where to start? 01-12-2010, 11:49 AM
AZGXP Re: 2008 GXP. Where to start? 01-12-2010, 12:03 PM
nmp0098 Re: 2008 GXP. Where to start? 01-12-2010, 10:35 PM
AZGXP Re: 2008 GXP. Where to start? 01-14-2010, 02:39 PM
elpasogxplover Re: 2008 GXP. Where to start? 01-18-2010, 09:16 PM
nmp0098 Re: 2008 GXP. Where to start? 01-20-2010, 10:53 AM
TallassJonG Re: 2008 GXP. Where to start? 01-20-2010, 11:41 PM
IR II IP IDEATH Re: 2008 GXP. Where to start? 01-23-2010, 04:48 PM
blk ls4 Re: 2008 GXP. Where to start? 01-30-2010, 11:16 PM
  1. #1 2008 GXP. Where to start?
    SE Level Member elpasogxplover's Avatar
    El Paso
    Hey i'm new to the forums, and i wanted to start modifying my car with basic bolt-ons. Which vendors carry the best items such as exhaust and intakes for a 2008 5.3L GXP? I haven't been able to find much on my own. Thank you.
  2. #2 Re: 2008 GXP. Where to start?
    Donating Users kfish's Avatar
    Ohio
    there isnt much available. IMO leave it alone.
  3. #3 Re: 2008 GXP. Where to start?
    El Paso
    What about body wise? Is there any special look that GXP drivers go for? I have a 500 dollar limit and just want to spoil my car a little bit.
  4. #4 Re: 2008 GXP. Where to start?
    Ohio
    no idea whats available for the 04+ cars.
  5. #5 Re: 2008 GXP. Where to start?
    El Paso
    I guess i'm going to have to search more. Hopefully someone has figured somethings out already that can be useful.
  6. #6 Re: 2008 GXP. Where to start?
    K&N makes a good intake...and it is around $300. Magnaflow makes an awesome catback...but it is pricey. Hogan Performance makes W-Body V8 Downpipes...which would be a great mod (catless of course).
    PFYC - PartsForYourCar.com - Performance Parts and Accessories for Your Late Model Vehicle
    Hogan Performance
  7. #7 Re: 2008 GXP. Where to start?
    New Mexico
    I put the K&N on mine and I have the Magnaflow Exhaust on the way to the house as I am writing this. I got the exhaust for about $675 from autopartswarehouse.com. It lists for $698 from them but they gave me an extra $25 off because I asked for it. A bit cheaper then the $900 list price from Magnaflow. Next on the list is a shift kit and Overkill tune (once available). I am also getting 18X8's all around next weekend to help mitigate the cost of tires in the future!! Boss wheels 328's with 40mm offset....just hoping that they fit!
  8. #8 Re: 2008 GXP. Where to start?
    Jan 2009
    Farmington Hills, MI
    There's a group buy for headers from Doug Thorley going on right now. We're getting them for $650 ($600 if they get enough deposits, please sign on and save me $50!!!), and they'll keep making them a $960 (iirc) after the buy. The headers have a downpipe for each bank (2.5") and merge under the car into a 3" outlet. They're 14 gauge mild steel, ceramic coated inside and out, and they come with a lifetime gaurantee.
    As for other mods, you'll have to show some ingenuity because although everything for an LSx can be made work, very little does out of the box. A lot of guys are going with N2O wet kits or the turbo kit. A guy over at LS1tech is running 11.49 at 117 with the turbo kit, a TEP transmission, 1.8 rockers, and a Magnaflow exhaust:
    YouTube - 11.49 @ 117 2006 Monte Carlo SS 5.3V8 Cartuning Turbo Kit
    2007 GXP, CAI Intake, 85mm MAF, LS6 Intake Manifold, 42# LS3 Injectors, PRC Ported and Milled 243 Heads - 11:1, 224/232-113+5 Comp Cam, PAC 1218 Springs, DT Headers (w/Custom Crossover Pipe), Cutout and Maxflows, TEP Transmission (3.29s), HP Tuned by Me, Pioneer Speakers and MTX Subs, 13.1 @ 108.7 on street tires at full weight.
  9. #9 Re: 2008 GXP. Where to start?
    New Mexico
    Just got the Magnaflow on the car last night. Was a little more difficult than I thought, as the hardware was rusted up good. I am still surprised at the fast that the stock exhaust was a one piece unit from the cat-back. I guess that I figured that it would have been 2 pieces considering the car is a four door. installing the new exhaust was easy and i luckily had some stainless fasteners that fit the new exhuast perfectly. No real clearance issues once the exhaust was up and moved around a bit.
    Sounds great and isn't too loud in the cabin under throttle. Good mellow rumble and at cruising speed just slightly louder than stock. Overal, very happy with it.
  10. #10 Re: 2008 GXP. Where to start?
    El Paso
    Quote Originally Posted by nmp0098 View Post
    send me the link to the sign up
  11. #11 Re: 2008 GXP. Where to start?
    Jan 2009
    Check out the headers thread by WilliamGT. You just need to join at LS1Tech and send WilliamGT a PM with your name, phone number and address. He doesn't post here other than his initial thread trying to get the group buy going. Once you are on the list, you need to call Nick at Doug Thorley Headers (1-800-347-8664) and give hime your credit card for the $100 deposit. It probably wouldn't hurt to let him know you are on the list. From what I understand, there is going to be a limited production run of 70 or so, with about 35 already purchased under the group buy. If you don't get on WilliamGT's list before the group buy ends (soon), then you are stuck buying them for $960 from Doug Thorley directly.
  12. #12 Re: 2008 GXP. Where to start?
    SE Level Member TallassJonG's Avatar
    Roseville, MI
    I peeked in to hear what you guys had for suggestions and I like them. I just have to wait for the wedding to be done with (May 1st) and I am going all out on my car. MagnaFlow and K&N CAI for sure and also going to put new shocks/struts (whatever it takes lol) Ohhhh I cannot wait for May 2nd.
  13. #13 Re: 2008 GXP. Where to start?
    Oxymoron: Civic - Fun IR II IP IDEATH's Avatar
    South
    aww no one reppin the flowmaster(sad face here) i got single chamber flowmasters on mine and i couldnt be happier with it, i also have the knn intake and i think its worth it mainly for sound and gas mileage.....oh and for my exaust it only cost me $250 installed for 2 mufflers and res delete.
    YouTube - grand prix gxp drive by
    couple other vids too. have fun with you GXP you should love it(mine is 08 as well)
    "Last night I didn't get much sleep so in the morning I made my coffee with red bull instead of water, I got half way to work before I realized I forgot my car."
  14. #14 Re: 2008 GXP. Where to start?
    Worcester, Ma
    i went with a cold air inductions cold air intake looks real nice and sounds good it was 266+shipping 2006 Grand Prix GXP Intake [501-0520] - $265.95 :: Cold Air Inductions - Cold Air Inductions Inc - Air Intakes
  1. 2008 gxp
    By robd5078 in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 11:31 PM
  2. 2008 grand prix vid
    By GrandPrix08 in forum Off Topic Discussion
    Last Post: 06-17-2009, 02:22 AM
  3. HID issue in 2008 GP
    By afish70 in forum Audio, Security & Visual Electronics
    Last Post: 01-06-2009, 05:42 PM
  4. My 2008 Mods
    By Keifer in forum General Tech Discussion
    Last Post: 07-02-2008, 11:06 PM
  5. Bgpm 2008
    By webracin in forum Shows and Events
    Last Post: 01-22-2008, 02:19 PM
