Thread: Car just shutting down....
Results 1 to 6 of 6
  1. #1 Car just shutting down....
    New Mexico
    Very weird things going on with the car. 06 GXP with 11,500 miles.
    Driving home and the car engine starts shuddering (lack of a better description) and shuts off. I shift it into neutral and restart the engine. The Service Stability Control light comes on and the cruise and electric locks don't work. I pull over to the side of the road, put the car in park and shut it off. I wait about 20 seconds restart the car and the warning lights are off and everything is working. I start driving again. The engine starts shuddering again about 15 minutes later, I press the gas to the floor and it kicks back in and runs like nothing is wrong. About 15 minutes later, the engine shudders and turns off again, at which point I notice white (not bluish) smoke behind the car. I pull over put the car in park and wait about 20 seconds. I restart the car and accelerate away. There is white somke coming from the exhaust for about 3 or 4 seconds and then it's gone. Car drives fine the rest of the way home, but I am not willing to make my 100 mile round trip commute with the car like this! There is no check engine light or anything other than the stability control thing.
    I really have no clue as to what is going on with the car, but it is kinda pissin me off....any ideas?
  2. #2 Re: Car just shutting down....
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    White smoke can be coolant. Worse case head gasket.. Check your oil for coolant.
  3. #3 Re: Car just shutting down....
    New Mexico
    So the dealership tells me today that the Crank Position Sensor was bad. Should know tomorrow if it is the right fix. At least the dealership could replicate the problem....it usually doesn't happen that way!!
    I did check the oil and it didn't have coolant in it, so the head gasket should be OK...
  4. #4 Re: Car just shutting down....
    CPS is very common on the 3800...not shocked it happened on your car too although it does suck...
  5. #5 Re: Car just shutting down....
    Nov 2008
    Chicago
    You're lucky it restarted. When mine went out the car just shut off and never restarted.
  6. #6 Re: Car just shutting down....
    New Mexico
    The problem has been fixed...CPS fixed the stalling, but then check engine light came on...catalytic converter was clogged...now everything is fixed and the car is back to normal...very nice!
  1. Blower motor running after shutting off 2006 GP
    By stratojet in forum General Tech Discussion
    Last Post: 03-21-2009, 11:04 PM
  2. GTP Shutting off
    By ryan88z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2008, 08:42 PM
