Thread: I need a little imput from the GXP guys
Results 1 to 8 of 8
  1. #1 I need a little imput from the GXP guys
    Ohio
    Alright ive got a guy here at home with a GXP that would like me to change his plugs and wires as well as his thermostat. I was curious as to how much of a b**** this job may be? And if any of you have any tips before i go into this as i'm not too familiar with the ls4. And where is the thermostat located on these? Is it right on top like an l67 or is it hidden under the intake manifold or something tricky like that? Thanks for any help an tips you can give me. A
    00 GTP demodded and forsale
  2. #2 Re: I need a little imput from the GXP guys
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Plugs and wires arent Horrible not much worse than the 3800's. pull the front dog bone and rock the motor forward seems to make is go a little easier. As for the T-stat, Its located in an odd spot. It located underneith the Exhaust manifold. So its in kinda a ruff spot
  3. #3 Re: I need a little imput from the GXP guys
    Ohio
    Ok thanks for the imput. For the thermostat will i have to remove the exhaust manifold or is there a way to sneak under or through it?
  4. #4 Re: I need a little imput from the GXP guys
    Dec 2008
    colorado
    I have read that u can do it with out taking of the manifold. But others have removed it to make it easier
  5. #5 Re: I need a little imput from the GXP guys
    Ohio
    Ok thanks. i guess ill see what im up against first hand an go from there.
  6. #6 Re: I need a little imput from the GXP guys
    Ohio
    o one more question. whats the plug gap?
  7. #7 Re: I need a little imput from the GXP guys
    Dec 2008
    colorado
    should say underhood
  8. #8 Re: I need a little imput from the GXP guys
    Ohio
    ok thanks.
  1. what do you guys think
    By qball98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 11:24 PM
  2. Hey guys
    By 1998xGTP in forum Introductions/Noob Questions
    Last Post: 12-24-2008, 10:24 AM
  3. hi guys!
    By Jakegday in forum Introductions/Noob Questions
    Last Post: 11-22-2008, 01:06 PM
  4. What do you guys think?
    Last Post: 10-20-2008, 12:03 AM
  5. attn: guys who are car salesman or guys who know them
    By shaferz in forum Off Topic Discussion
    Last Post: 03-25-2008, 05:05 PM
