Thread: CAMS for the LS4
Results 1 to 14 of 14
  1. #1 CAMS for the LS4
    SE Level Member bladerunner's Avatar
    Feb 2009
    AZ
    So Next month my plans are to finally do the exhaust, Decided im keeping it 2 1/2 inch all the way back, puttin on some flowmaster super 44's and resonator removal. Ordering a predator diablo sport programmer and probably doing a little cosmetic work as well. My question is are there cams out for the LS4? I have been searching and not coming up with much. Any input on my plans for next month are appreciated as well.
    2006 GXP, stock for now
  2. #2 Re: CAMS for the LS4
    Banned - Busted For Scamming
    Feb 2009
    what are you going to do with the diablosport?
  3. #3 Re: CAMS for the LS4
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Honestly id avoid the Diablo. Its fine and all but doesn't offer trans support. And Kinda crappy customer service. One GXP owner has both the Diablo and the new superchips programer. His plan was to compare both once diablo got all there updates. Well i think its been close to a year and he has given up and selling it because of lack of suport and crappy customer support. As far as cams. Yes and no. Most any cam for a LSX will work. But if your keeping DOD you cant go to big with the cam. There have been a couple guys swap cams. However they have ran into some issues. One of them is if the cam moves the power band higher, then while racing when you shift 1-2 you could possible be completely out of the Power band. There are some other things that if u really want to go ahead with the swap ill get the info straight and get it for you.
  4. #4 Re: CAMS for the LS4
    Feb 2009
    AZ
    Thanks for the info on the diablo sport! My friend with a SRT8 has one and talked it up good, I did see the super chips programmer, same price really. I think mainly i want to see what kind of high octane tunes each has, I will check out the superchips programmer more. I used HP Tuners on my old cobalt ss, Liked that program but i want something easier. Looking to get the most power i can out of one if im spending close to 400 bucks.
  5. #5 Re: CAMS for the LS4
    Dec 2008
    colorado
    hey no problem. If u found a diablo cheap enough, i havent herd anything actually bad about the tune itself. Just when buying brand new way better options out there.
  6. #6 Re: CAMS for the LS4
    Feb 2009
    AZ
    Yeah, and im big on support so superchips may wind up being the better of the 2. Wanna get rims next tax return so thats the 2nd move once the motor is all set. Rims are a bit hard to find as well when im shoppin around. Wheelsnext.com has good selections.
  7. #7 Re: CAMS for the LS4
    Not to knock the handheld tuners...but why not drop the extra money and get a HP Tuners...if they are applicable on the LS4 powered cars...just seems like you would get way more accurate readings and a WAY better tune...plus you can tune the transmission and everything else...
  8. #8 Re: CAMS for the LS4
    Feb 2009
    AZ
    If i knew how to use HP i would buy it. I made the mistake of having someone that "knew" what they were doing with HP tuners on my SS cobalt. pistons 1 + 4 were then destroyed lol. Tuning the Trans is something i want on the programmer, still lookin at superchips tho to see if they support trans.
  9. #9 Re: CAMS for the LS4
    Feb 2009
    AZ
    Also random question, Will a resonator removal thow any codes? Never had that happen on any other cars but figured i would ask. This way I should get my tuner first then do exhaust to delete the code completely from the PCM.
  10. #10 Re: CAMS for the LS4
    Dec 2008
    colorado
    I have not herd of resonator removal throwing any codes. it shouldn't since there not any sensors after the Res. But anymore better safe asking then assuming.
  11. #11 Re: CAMS for the LS4
    SE Level Member cue244's Avatar
    New Hudson, MI
    Just a quick thought, on my old 300c I had the Superchips, sold it, and went with the Diablo. The Diablo blew the superchips out of the water.
  12. #12 Re: CAMS for the LS4
    Dec 2008
    colorado
    Diablo isnt crap just they dont care much about the LS4 powered cars. We are to small of a market for them TO Care about. I am personally HP tuned, by a local tuner.
  13. #13 Re: CAMS for the LS4
    Feb 2008
    I love my HPT. It's not all that hard to learn. There is plenty of information out there on tuning. They're forum is full of people tuning LSX motors who can help you with any questions.
  14. #14 Re: CAMS for the LS4
    Feb 2009
    AZ
    Quote Originally Posted by cue244 View Post
    only thing i worry about is no tranny support. other then that how was the power/throttle response on the diablo? I called there tech support and the guy on the phone sounded like a reject....no help lol ha
  1. Those with xp cams...
    By GTP4 in forum PCM Tuning
    Last Post: 01-29-2009, 04:23 PM
  2. COMP Cams 1.8:1
    By TMC in forum General Tech Discussion
    Last Post: 10-14-2008, 08:50 PM
  3. intense cams
    By bad1999gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2008, 11:08 AM
  4. Those with XP and VS cams step in
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 01:13 PM
