Thread: Low temp. Stat
Results 1 to 2 of 2
  1. #1 Low temp. Stat
    SE Level Member Rossko85's Avatar
    Feb 2009
    Danville, IN
    Could someone advise which way I should go on a stat upgrade...i have a Hogan Dp with a modular race pipe with a res delete into two borla turbos....gets warmer much faster now and works a lil harder to get back down to temp....
    whats your thoughts?
    K&N Air CHARGER, ALTEZZA clr out tails, UltimateHID digital head lamp kit, Superbrightleds.com frt. corner markers, rev lamps, lic. plt lights, silverstar metallic clear turn sig. bulbs, custom mesh inserts; bottom fascia intake innlets. 5% limo wrapped, front and rear color match brows, engine hose dressing: BLUE
  2. #2 Re: Low temp. Stat
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by Rossko85 View Post
    My thought is that exhaust work should not have made your car hotter all the time. You could drop to a 180º thermostat, but you would want to get the fan control points adjusted to match.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. should i get a 180 or 160 t stat?
    By 98gtp1000 in forum General Tech Discussion
    Last Post: 02-21-2009, 10:15 PM
  2. Which t-stat should I get?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2008, 08:49 PM
  3. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  4. 180* T-stat
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2008, 06:03 PM
  5. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
