Thread: P0135 need pcm pin out for 5.3L to rewire
Results 1 to 2 of 2
  1. #1 P0135 need pcm pin out for 5.3L to rewire
    Nov 2023
    Minnesota
    I have replaced sensor twice.
    Replaced pigtail to o2 sensor 1.
    I have 12v power to harness.
    Any other ideas besides replacing 3 wires back to the pcm? Does anyone have the pin out diagram and with wire color codes and descriptions for the 3 wires back to the pcm. Been trying to pull wires through main harness which is a chore in it self not to break any wires going back to PCM.
  2. #2 Re: P0135 need pcm pin out for 5.3L to rewire
    Nov 2023
    Minnesota
    Solved, found wires receiving magnetic field through main harness. Pulled wires out and wrapped in electrical tape and separated in new wire loom with just the alternator cable. Problem solved
    It was all entangled so I cut wires at pcm and butt connected with heat shrink connectors
  1. P0135 Diag Code
    By p coico in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2016, 12:18 AM
  2. P0135
    By KennethJohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2015, 03:01 PM
  3. can't get rid of P0135!!
    By des19 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2012, 09:20 PM
  4. getting a P0135 code
    Last Post: 06-28-2012, 11:01 PM
  5. P0135 - replace o2 sensor?
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:08 PM
