Thread: Engine swap question
Results 1 to 4 of 4
  1. #1 Engine swap question
    Feb 2022
    MO
    Chats
    I have a 08 GXP with a blown motor. Do I need to put a 07 - 08 motor in there or can I put the previous years in as well?
  2. #2 Re: Engine swap question
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    If you swap to a lower year, you'll also need to swap the engine wiring harness. The harnesses are different in ever year of the GXP. Otherwise, you should have no issues.
  3. #3 Re: Engine swap question
    Nov 2019
    WI
    Chats
    Quote Originally Posted by Deandre328 View Post
    I believe the reluctor wheel was changed to 52 teeth in 2007. Therfore the ecu and wiring are different.
  4. #4 Re: Engine swap question
    May 2016
    Burns City, Indiana
    Chats
    12
    No you must use engine with same color crank sensor, 08 will be 58x crank sensor and 4 X cam older engines 05/06 ran 24x crank and 1x cam
  1. Engine swap question
    By 67eftw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2015, 07:27 PM
  2. engine swap question?
    By JimSWylie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2013, 07:06 AM
  3. question on engine swap
    By beauchamp48 in forum Introductions/Noob Questions
    Last Post: 10-29-2012, 05:48 PM
  4. engine swap question
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2012, 09:50 AM
  5. Engine Swap Question
    By Points70 in forum General Tech Discussion
    Last Post: 04-18-2012, 06:45 AM
