Thread: 2007 GXP no crank no start
Results 1 to 6 of 6
  1. #1 2007 GXP no crank no start
    Mar 2014
    Barrie, Ontario CANADA
    SO I have a 2007 GXP with ~80k miles on it. It has decided to stop starting. It seems like the starter gets the signal to start as you can hear it clack when the key is turned, it just doesn't seem to get the start signal for long enough to actually engage the starter. I have put a new starter in and same issue. Checked battery connections and ground connections to engine and trans and ohmmeter reads good connection. Tried connecting another battery direct to starter terminal and engine frame but still no go. Inside the car when the key is turned to start the dash dies and other weird things happen, sometimes the horn goes sometimes the trunk opens etc.
    I think the battery may be weak and will try installing another one tomorrow, but since I tried a direct connection to the starter from another battery I'm not sure if this will help.
    Has anyone experienced this issue ?
    I have looked at the fuse block and no blown fuses (didn't expect there to be as the starter does get some power signal, as I said above it just doesn't seem to be for long enough to engage the starter.)
    Appreciate any help or suggestions as this is starting to tick me off.
  2. #2 Re: 2007 GXP no crank no start
    St. Louis
    Try a fresh battery. When they get weak you can get weird things like that.
  3. #3 Re: 2007 GXP no crank no start
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by FlyGXP View Post
    load test the battery to start. if load test shows good battery, the positive cable can corrode internally.
    08 grand prix NA3800
  4. #4 Re: 2007 GXP no crank no start
    Mar 2014
    Update on this problem.
    I did replace the battery as the old one failed load test.
    Car was working fine until yesterday, now it wont start again and does the same clack sound and lights flash sometime horn sounds etc. Not sure where to look now. Ideas???
    Thanks
  5. #5 Re: 2007 GXP no crank no start
    Apr 2014
    commerce twp,mi
    reading to me like the alternator may not be charging.
  6. #6 Re: 2007 GXP no crank no start
    Kemmerer, Wyoming
    might be the starter this time
  1. No start or crank plz help
    By Toocidnab in forum 04+ Specifics
    Last Post: 11-19-2017, 12:43 PM
  2. 2007 GP LE 3800 stalled. no crank. no codes HELP PLEASE!
    By jghibb in forum General Tech Discussion
    Last Post: 04-18-2017, 03:40 AM
  3. No crank no start.
    By Undead auto in forum Engine
    Last Post: 02-26-2017, 04:42 PM
  4. Crank but no start.. Help!
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 11:31 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
