Thread: Oil Pressure Warning
Results 1 to 8 of 8
  1. #1 Oil Pressure Warning
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    I've gotten the "Low Oil Pressure" light a couple of times in the past week. There's plenty of oil, and the pressure sensor is a brand new ACDelco unit.
    Is it the oil pump? Or something else entirely?
  2. #2 Re: Oil Pressure Warning
    Kemmerer, Wyoming
    Chats
    60223
    in my case it was the pick up tube O-Ring in the oil pan. same thing happened to me right after I had the cam and lifters replaced. it happens a lot on LS engines.
  3. #3 Re: Oil Pressure Warning
    Jul 2016
    Brevard County, FL
    Chats
    I forgot to mention, I already changed the O-ring as well....
  4. #4 Re: Oil Pressure Warning
    Chats
    243824
    sensor could be bad new in the box. it happens, even with delco parts.
  5. #5 Re: Oil Pressure Warning
    Chats
    243824
    pretty sure theres a screen under the sensor you need to clean or change. it clogs up.
  6. #6 Re: Oil Pressure Warning
    Kemmerer, Wyoming
    Chats
    60223
    after I posted, I saw in an older thread that you had done that. it could be the oil pump, I don't know how to tell, but if you drop the pan again and have extra money, Brandon Furches, aka LS4King, has new stamped steel and one other upgraded oil pan, supposed to be better, and is supposed to make the 4T80 easier to do. Good luck.
  7. #7 Re: Oil Pressure Warning
    May 2016
    Burns City, Indiana
    Chats
    12
    There is also a screen under sensor in the port, remove replace/clean it out. If that doesn't fix issue (or you install manual guages and prove low oil pressure) you may need to drop oil pan and replace the oil pump pickup oring, it's said always use the green one.
  8. #8 Re: Oil Pressure Warning
    Jul 2016
    Brevard County, FL
    Chats
    Again, already changed the O-ring. Can't get the screen out to clean it, no pick available anywhere fits in the hole.
    I ended up changing the oil pump. Went from 22 to 45 psi.
  1. Tire pressure warning
    By danf in forum General Tech Discussion
    Last Post: 07-20-2021, 07:51 PM
  2. What would cause ABS and Tire pressure warning lights to come on?
    By Mad Bohemian in forum General Grand Prix Discussion
    Last Post: 04-16-2021, 06:03 PM
  3. Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2014, 09:31 PM
  4. Tire pressure warning wont shut off
    By ms3206 in forum General Tech Discussion
    Last Post: 08-23-2011, 11:20 PM
  5. Tire Pressure Warning
    By BHMJohn in forum General Tech Discussion
    Last Post: 09-30-2008, 08:38 AM
