Thread: Misfire Code
Results 1 to 6 of 6
  1. #1 Misfire Code
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Getting the generic P00300. The solution offered by the parts store was to replace all the wires and coils (the plugs are less than two months old). I have a set of wires left over from my Monte Carlo, but I am not spending $500 to replace all the coils for no reason.
    Is there any way to get this narrowed down?
  2. #2 Re: Misfire Code
    cat could be clogged up.
  3. #3 Re: Misfire Code
    A live data scan tool that can read each cylinder for misfires is what you need. This way you can figure out what cylinders are causing the P0300.
  4. #4 Re: Misfire Code
    Apr 2014
    commerce twp,mi
    OT here but do you have a recommendation for one? preferrably not one requiring one of them fancy schmancy phones and reasonably priced
    08 grand prix NA3800
  5. #5 Re: Misfire Code
    I believe this one by Bosch does but they also sell a few different version with more features of this style scan tool. I would do some reading and maybe watching reviews to get a better idea.
    Amazon.com
    I'm spoiled because I have a small handheld scanner for quick stuff and then I use my laptop with tuner software if I really need to figure something out. I haven't looked real hard at what all these scan tools do now. Pretty much something in the $100-200 range should be able to read codes, do live data and also do ABS functions now.
  6. #6 Re: Misfire Code
    Jul 2016
    Brevard County, FL
    Misfire code disappeared when seven others appeared. All those are fixed, and no reocurrence.
  1. Misfire (no code)
    By Acdc88 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2016, 05:29 PM
  2. P0303 Code. Help!!!! Misfire!!!
    By cdubb79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2013, 11:56 PM
  3. 4-5k rpm misfire, Code P0300.
    By trailshredder in forum Engine
    Last Post: 11-13-2011, 07:43 PM
  4. Code p0304 misfire 4
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 02:21 PM
  5. Can a bad O2 sensor cause a misfire code?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 08:01 AM
