Thread: Can Someone Identify the Blue Part on Top of the Engine?
Results 1 to 12 of 12
  1. #1 Can Someone Identify the Blue Part on Top of the Engine?
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Chats
    It doesn't appear in any of the engine diagrams I can find.Can Someone Identify the Blue Part on Top of the Engine?-ls4part-jpg
    Can Someone Identify the Blue Part on Top of the Engine? Attached Images
  2. #2 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Jul 2016
    Brevard County, FL
    Chats
    Also, what is supposed to attach to this fitting? We can't find a hose attached to it on either engine. Not getting any vacuum leak codes...Can Someone Identify the Blue Part on Top of the Engine?-ls4part2-jpg
  3. #3 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Chats
    243824
    ive got a 5.3 in my tahoe, so not exactly the same set up, but my vac line from the top of the intake goes to a valve cover's pcv valve. its where you would install a catch can. between that line.
    that other line looks fat enough to be evap related. im not even sure where im looking either in that pic.
  4. #4 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Jul 2016
    Brevard County, FL
    Chats
    It doesn't go into a valve cover, it's in the valley between them. The second picture is below and to the left of the throttle body.
  5. #5 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Chats
    83662
    Many LS engines have the PCV line into the valley cover and not the valve covers. But the LS4 should have a tube coming out of the rear valve cover that the PCV hose goes into.
    The port on the intake manifold is likely another port used in a different applications. If you can put your finger over it and there is no air being sucked in, that port is blocked. My guess is that it's a PCV or EVAP line connection that just isn't used.
  6. #6 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Jul 2016
    Brevard County, FL
    Chats
    I cannot, of course, nail down the part number on the PCV hose for the LS4. However, every hose I can find is rubber or plastic. This thing is metal.
  7. #7 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Dec 2013
    Enfield
    Chats
    On my 08 that part is original and plastic, it goes to the port on the rear valve cover. The second picture that is a dummy post, nothing goes there and it has no vacuum.
  8. #8 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Jul 2016
    Brevard County, FL
    Chats
    Thank you, but what is it called, so I can order another one?
  9. #9 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Chats
    83662
    You will have to contact a GM dealership directly for that.
    The vehicle is over 10 years old and they don't have to make parts for it anymore. I don't see it listed on GM parts direct anymore so if there is a part number for that part, it's new old stock. They would have a complete parts list breakdown for it.
    Or just do what anyone else would do and buy a piece of rubber hose to make a new one if you needed to do that.
  10. #10 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Dec 2013
    Enfield
    Chats
  11. #11 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Jul 2016
    Brevard County, FL
    Chats
    No luck. I ordered that. It's black plastic and connects to the MAF sensor, not the engine. The one I have is just fine.
    Anyone else?
  12. #12 Re: Can Someone Identify the Blue Part on Top of the Engine?
    Dec 2013
    Enfield
    Chats
    ENGINE ASM-5.3L V8 PART 2 CYLINDER HEAD AND RELATED PARTS
    As I said it's plastic on my car, the part I gave you is what is listed as it goes to the rear valve cover . If you have not owned the car since new chances are it's been replaced, possibly with a part from a truck or some other doner vehicle. It's not available so used or custom fit a new piece is your choice of repair.
  1. Trying to identify a part
    By lawadm1 in forum General Grand Prix Discussion
    Last Post: 08-01-2019, 02:28 PM
  2. Help identify part
    By Weedaho in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2015, 03:47 PM
  3. help me identify this part
    By aeraxeur in forum General Grand Prix Discussion
    Last Post: 07-17-2013, 09:29 PM
  4. Can anyone identify this part?
    By JoeinMN in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2012, 11:15 AM
  5. Anyone able to identify this part?
    By txslow6 in forum General Tech Discussion
    Last Post: 01-17-2012, 08:59 AM
