The irony is tangible.
Hurricane, you act like the name you chose. For the record, I stopped replying to your posts long ago based on your perceived attitude and how you wrote responses to people attempting to help you.
Enjoy your LB1 issue.
:th_popcorn:
GPF is cheap and doesnt offer anything else
Cheap bastards :p
Sadly, OP hasn't been back for a few days. Maybe he's busy reading up on super technical automotive lingo like "intake tube" and "oil dipstick" :D
I'm happy to have provided so much amusement for all of you, just because I only speak English. For the record, the codes disappeared on their own and haven't reappeared. All I did was change the sperk plugs on the rear bank and not return to Wawa for gas. So, no vacuum leaks, just ****ty gas.
Looks like I missed the party..... You should probably stay away from working on cars.
you can lead a horse to water, but you can't make it drink.
Can't make an english major spell properly either.
A defective O2 sensore heater will trip an oxygen sensor code, but a lean condition will not. That does not mean that the sensor is good, however. I finally broke down and bought a decent scan tool that can do fuel trims and monitor O2 sensor activity. If the fuel trims improve when idle is raised to 2,000+ rpm, suspect a vaccum leak. If they remain about the same, suspect a malfunctioning O2 sensor. In normal operation, the O2 sensor will fluctuated between ~200 to 800 millivolts. Raising idle should cause it to go rich until the idle is reduced, when it should return quickly to normal. You could also try removing the sensor and cleaning the carbon with carb cleaner if you feel lucky. Glad to hear it cleared by itself. Maybe good gas and an "Italian Tuneup" was all that was necessary. I am sorry to hear of your heart problems. I have been "mechanic free" for the last 25 years. Learning and gaining knowledge is the key to remain that way.
Thanks for reviving this one I enjoyed reading it AGAIN.
I'm pretty sure op's intentions was to purposely misspell words to poke fun at the posters. My personal favorite was "sperk plugs"
Sent from my SM-N920V using Tapatalk
