Thread: P0641 and arcing coil packs
Results 1 to 2 of 2
  1. #1 P0641 and arcing coil packs
    Jul 2017
    Big lake mn
    I have an 06 gxp that just barely starts-runs. It goes too reduced power, no stability or traction control, low oil pressure with engine code p0641..the battery was bad so i replaced it but onced started you can hear and see the front coils arcing. It still flashes all the codes and warnings. Anyone have any ideas on the matter?
  2. #2 Re: P0641 and arcing coil packs
    St. Louis
    Well, if you see arching at the coils then I'd lean towards bad plug wires or a cracked coil. Also be sure that the battery cables are clean and tight as these cars are sensitive to bad/missing grounds. Will cause all kinds of strange things.
    For the code, read through this thread it may help--> http://www.grandprixforums.net/threads/89729-P0641-Code
  1. Bad coil packs?
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 03:20 PM
  2. Coil Packs
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 12:16 PM
  3. coil packs keep going out???
    By chamberlain198437 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 10:33 PM
  4. Coil Packs
    By snodly in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2009, 09:04 PM
  5. coil packs
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2009, 09:29 AM
