Thread: Something loose in the front end
Results 1 to 10 of 10
  1. #1 Something loose in the front end
    Kemmerer, Wyoming
    when I accelerate in my GXP from a stop, I can feel something loose. at first I thought it was an engine or trans mount, but now that I have been paying more attention, I'm wondering if the transmission is slightly hesitating.
    it could be nothing at all except that I'm used to my 2001 and the rapid throttle response and all the poly engine/trans mounts.
    what do you guys think?
  2. #2 Re: Something loose in the front end
    Dec 2013
    Enfield
    Does it act the same while using Tapshift?
  3. #3 Re: Something loose in the front end
    Kemmerer, Wyoming
    I'll try it and see
  4. #4 Re: Something loose in the front end
    Kemmerer, Wyoming
    It doesn't really Rev up or clunk, it just feels like a worn mount or a slight hesitation. I put it in tapshift and didn't feel it, but I couldn't duplicate the conditions I felt it before
  5. #5 Re: Something loose in the front end
    Dec 2013
    Enfield
    If it is the transmission hesitating, it usually does it less in Tapshift mode. Something to monitor I guess. A poly top mount or flipped factory mount may help in the diagnostics if you have not done that mod yet.
  6. #6 Re: Something loose in the front end
    Kemmerer, Wyoming
    I was thinking I would do the poly mounts.
  7. #7 Re: Something loose in the front end
    Arizona
    Lower mount man front lower splits in half and the rear falls apart
  8. #8 Re: Something loose in the front end
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    It may be the "nut loose behind the wheel"....LOL
    On a serious note, I had a shop press in the Moog lower control arm bushings and one worked its way loose. With the bushing out of the hole it was allowing the control arm to move around the front mount bolt. It would make a loud clunk on acceleration or braking but not every time, the attitude of the pavement had to be right so that it unloaded the RF wheel and allowed the control arm to shift. Spot welded it back in, all is good. May not be your specific problem but I would check all front suspension bushings first.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  9. #9 Re: Something loose in the front end
    Kemmerer, Wyoming
    I think my next paycheck will go towards a poly trans and a new engine mount from X11 nut
  10. #10 Re: Something loose in the front end
    Dec 2013
    Enfield
    Definitely check the sway bar endlinks, but you will usually hear a clunk with those.
  1. Springs loose?
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2016, 04:59 PM
  2. something is loose
    By eyelobes in forum General Grand Prix Discussion
    Last Post: 10-17-2014, 11:14 PM
  3. Front Right Quarter Panel Loose?
    By Mr D in forum General Tech Discussion
    Last Post: 12-04-2012, 01:30 PM
  4. Front bumper is loose-from what?
    By GTLGDP in forum General Tech Discussion
    Last Post: 05-08-2012, 01:14 PM
  5. something seems loose
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 03-08-2008, 01:55 PM
