Thread: 180 degree thermostat
Results 1 to 8 of 8
  1. #1 180 degree thermostat
    SE Level Member IGGYS 2008 GXP's Avatar
    Jan 2009
    Chesapeake, VA
    Ok, so this might be a stupid question but I had to ask anyway. I have been reading about the 180 degree thermostats a bit. I am just curious if anyone knows how installing one would affect the factory warranty on the motor.
  2. #2 Re: 180 degree thermostat
    SE Level Member silvergxp's Avatar
    Nov 2008
    St. Louis
    I am running a 160 in my gxp for two years now, I dont know about warranty, but to give you a heads up your check engine light will pop on for a day or so like mine did, has not been on after that.
  3. #3 Re: 180 degree thermostat
    I live here. UR LOSN's Avatar
    Rockford, IL
    It wont void any warranty. It will keep the motor cooler... but your fans are set to come on when it gets a lot hotter.......
    apparently you can throw a code for running a 160 on the GXP's as well. with a simple tune you would be able to delete the code for good...so it wont keep popping back up...
  4. #4 Re: 180 degree thermostat
    SE Level Member Rossko85's Avatar
    Feb 2009
    Danville, IN
    where can i get a therm.????? 08 GXP
    K&N Air CHARGER, ALTEZZA clr out tails, UltimateHID digital head lamp kit, Superbrightleds.com frt. corner markers, rev lamps, lic. plt lights, silverstar metallic clear turn sig. bulbs, custom mesh inserts; bottom fascia intake innlets. 5% limo wrapped, front and rear color match brows, engine hose dressing: BLUE
  5. #5 Re: 180 degree thermostat
    Nov 2008
    St. Louis
  6. #6 Re: 180 degree thermostat
    Feb 2009
    Danville, IN
    so answer me this....all the parts that are available for the GXP only go up to 2006...nothing is showing for 07 or 08.....are the cars the same set up as far as engine and positioning of parts etc...will these parts that are avail fit on the 07 and 08....i just cant assume ya know....I dont see why not...i mean even the down pipe companys want special orders put in...and havent done anything with the GXP later models...who knows.. could somebody tell me...
  7. #7 Re: 180 degree thermostat
    GTX Level Member Panther427's Avatar
    Dec 2008
    colorado
    Wellthe O7 year was the most limited, so i think most companys just forgot about us. But as far as i have seen no changes were made during the production run, except wheels.
  8. #8 Re: 180 degree thermostat
    milford
    your local advance or autozone will almost certainly have exactly what u need. and its prolly cheaper. thats where i got mine from.
    even if you walk on water, some will say that you cant swim...
  1. GTP Question New To The 90 Degree Motor
    By 05grndprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2008, 08:15 PM
  2. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  3. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
  4. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
  5. 70+ Degree temps for 2 days and then roof falls in!!!
    By GeddyLee in forum Off Topic Discussion
    Last Post: 03-05-2008, 10:16 PM
