Here's my issue, any help would be appreciated!
I have a 1999 GTP. About a month ago I noticed the coolant temp fluctuating. Being it was a hot day and we were on kind of a long trip (1 hour and a half) I wasn't too concerned. To my knowledge, the temp has NEVER went into the red. I took a look at the reservoir and noticed it was low, so I filled it up. About a week later I started to notice a coolant smell, not coming from the exhaust at all, but seemed it was coming from engine bay and sometimes the A/C vents when the A/C was running.
I thought it might have been from air being in the cooling system, I again filled the reservoir and tried to bleed the coolant system by getting a good stream from the bleeder valve above the thermostat. I have now noticed some puddles under the car and the coolant temps still fluctuate BUT never getting into the red.
I have noticed the upper and lower hose never fill like it has pressure, but it did feel like it had pressure after I bled the system. Now, I'm back to the hoses being limp with the coolant being low and fluctuating temps still.
Then today the check engine light came on and had it checked and it turned out to be a misfire on #5 cylinder.
My question is could these be the symptoms of a bad thermostat? Or my worst fear, a bad head gasket? Should I just replace the thermostat and replace the plugs and hope for the best? Looking for some good advice!
Thanks in advance people!
