Thread: Heat / AC Issues
Results 1 to 7 of 7
  1. #1 Heat / AC Issues
    Troy, MI
    Recently my AC and heat have stopped working on my 2003 GTP. When I first turn the blower to 1, the RPMs increase slightly (as they did before when it was working) and I can hear the motor start. Within 5 seconds, the RPMs drop and nothing happens. This occurs on all 5 settings. I noticed when driving 55 MPH+, if i crack a window (aka create a pressure variance) hot or cold air (which every the thermo is set at) flows through the vents.
    I have already changed the blower motor resistor with out any results. I am wondering if it is the motor itself since i have checked all the fuses and they seems to be okay. My defroster works fine, just no heat/AC.
    I also live in the Detroit area and it is starting to get cold. Looking for any help I can get.
    Thanks,
    - El Ponchovilla
  2. #2 Re: Heat / AC Issues
    Unplug the motor and try applying power straight to it and see what it does.
  3. #3 Re: Heat / AC Issues
    all your parking lights work and head lights when the fan is turned on? seen one car kill the head or parking lights when the fan was turned on, forget witch ones.
    ended up being the ignition harness.
  4. #4 Re: Heat / AC Issues
    Troy, MI
    havent noticed any related electrical issues
  5. #5 Re: Heat / AC Issues
    Troy, MI
    I ended up buying a new m blower motor. Is an install of this time consuming and/or difficult?
    When changing the resistor the hardest part was simply getting under the glovebox, since i am a 200+ pound man
  6. #6 Re: Heat / AC Issues
    Jan 2014
    AR
    Swapping the blower motor in a 97-03 is cake. Easy. If getting in there is too cramped, just take out the passenger seat first.
  7. #7 Re: Heat / AC Issues
    Troy, MI
    replaced the motor. blows hotter and harder than a top dollar Saigon whore
  1. No heat on drivers side, but heat on passenger side.
    By maceman in forum General Tech Discussion
    Last Post: 04-05-2013, 06:57 PM
  2. Help - Electrical Ac/ Heat issues 2002 Grand Prix GT
    By Brian1975 in forum General Tech Discussion
    Last Post: 07-15-2012, 04:01 PM
  3. Mom's got no heat.
    By chevyy1212 in forum General Tech Discussion
    Last Post: 10-31-2011, 09:34 AM
  4. 2001 grand prix 3800 heat issues. HELP PLEASE
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 06:47 PM
