Thread: 2004 gtp starting and stalling
Results 1 to 7 of 7
  1. #1 2004 gtp starting and stalling
    Oct 2015
    Indiana
    So my gtp has been starting and dying unless I push on gas..had a engine light for egr so I replaced it but still is dyin. Any ideads? I'm guessing it's something with the electric throttle body as my regal and 2000 gtp never do this
  2. #2 Re: 2004 gtp starting and stalling
    Clean the throttle body and report back.
  3. #3 Re: 2004 gtp starting and stalling
    Oct 2015
    Indiana
    Can I use brake cleaner? I removed intake and throttle body is filthy I'll prob have to remove it
  4. #4 Re: 2004 gtp starting and stalling
    Use whatever, brake cleaner works good.
    Unbolt it and unplug it and clean it up.
  5. #5 Re: 2004 gtp starting and stalling
    Oct 2015
    Indiana
    Thanks! Hasn't died since, it was filthy! Now to figure out my miss issue..happens under 1800 rpm feels as if I'm running out of gas or something (falls on its face) but if I floor it or give atleast half throttle it comes right out of it
  6. #6 Re: 2004 gtp starting and stalling
    Sep 2015
    Houston TX
    I had a bit of that. Are you using any coolant? Is there white smoke out the pipes at start up?
  7. #7 Re: 2004 gtp starting and stalling
    Nov 2015
    Kansas
    My daughters car doing this. Using coolant like crazy and see some smoke. Car stalling! Can you send me pick of throttle body and intake. Want to clean it up! Thanks!
  1. Car stalling right after starting
    By sillypants03 in forum General Grand Prix Discussion
    Last Post: 03-01-2013, 03:46 PM
  2. Stalling Issue's when starting!! Help!!!
    By nickdemio in forum General Tech Discussion
    Last Post: 07-27-2011, 06:23 AM
  3. 01 GTP stalling randomly not starting
    By xekrubx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2011, 06:30 PM
  4. stalling after starting
    By cruse in forum General Tech Discussion
    Last Post: 02-24-2010, 10:25 AM
  5. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
