Thread: Crank case breather
Results 1 to 5 of 5
  1. #1 Crank case breather
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Where do you put a crank case breather, oil cap? Purpose of this? -98gtp
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Crank case breather
    The purpose would be to create an unmetered vacuum leak that would need to be tuned for...usually only done on big bulds where pressure may grow too fast on a WOT run vs the limits of the system on the motor from the factory.
    Yes..most do it instead of the valve cover cap.
  3. #3 Re: Crank case breather
    Topeka, ks
    No point on a virtually stock motor then?
  4. #4 Re: Crank case breather
    The only point would be to have an unmetered vacuum leak that you need to then fix.
    I have a feeling if you are asking about this..the car is running good and you have time on your hands. Might as well fudge it up a bit and give yourself something to do.
  5. #5 Re: Crank case breather
    Topeka, ks
    Lol no I was just curious haven't got car fixed yet that's tonight project
  1. Too much crank case pressure
    By Joepaakk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2015, 11:10 AM
  2. Crank case pressure
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2013, 01:03 AM
  3. Question about L32 crank case pressure
    By RamairGTP2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2012, 02:29 PM
  4. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
