Thread: mysterious shredding belt
Results 1 to 11 of 11
  1. #1 mysterious shredding belt
    SE Level Member wpbboy81's Avatar
    Sep 2011
    west palm beach, fl
    I'm hoping someone here can help me. Last week I noticed my belt was beginning to shred on the inner side closer to the engine. I planned to change it that wknd, but it didn't make it. It shredded on Wednesday night, and I replaced it. Then 2 days later the new belt shredded apart also. Before installing the a new belt, I checked all pulleys for play, and all seemed fine. The power steering pulley was a little tougher the others, I'm not sure if that's unusual or not. I checked again after the belt was on....no problems. I don't see it rubbing on anything. Well today (2 days later again), my belt shredded again. Can anyone please help me out or point my in the right direction. It's a 2000 gtp BTW
    98 GTP, VS cam, SD headers, 3" full exhaust (cat/resonator/ubend deleted), genV blower, 3.4 MPS, ported LIM, open cone air filter, custom tune, alternator power cable, fuel pump rewire, AL 104s, 180 stat, flipped dog bones, 04 GTP front rotors w/ F-body calipers, and the oh so comfortable monte carlo seats
  2. #2 Re: mysterious shredding belt
    which belt?
    what does its tensioner look like? is it bouncing up and down a lot?
  3. #3 Re: mysterious shredding belt
    Sep 2011
    west palm beach, fl
    The main drive belt. The tensioner isn't bouncing around much at all, seems pretty sturdy.
  4. #4 Re: mysterious shredding belt
    Do you have the routing diagram? Just making sure all accessories are heading the right way.
  5. #5 Re: mysterious shredding belt
    Sep 2011
    west palm beach, fl
    Yes i have the diagram sticker mounted on the frame. I've taken it off so many times between this and my old car that I don't even need it, but I started to second guess myself this time and looked at it for verification. Everything is routed correctly. What's weird is I check it before any trip now, and there's no kind of wear on it at all.
  6. #6 Re: mysterious shredding belt
    I have seen some folks having that issue and being one rib off on say the bottom of the crank.
  7. #7 Re: mysterious shredding belt
    Sep 2011
    west palm beach, fl
    I'll double check it again. Looks ok. This is frustrating lol. It seems fine, but then SNAP out of nowhere. I noticed my supercharger belt is one rib off. No matter houw many times I put it on properly, it moves back. But only on the tensioner and free pulley. It's on properly on the supercharger and crank.
  8. #8 Re: mysterious shredding belt
    Jul 2010
    Coquitlam,BC,Canada
    Belt is out of alignment.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: mysterious shredding belt
    Sep 2011
    west palm beach, fl
    How do I put it back in alignment?
  10. #10 Re: mysterious shredding belt
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by wpbboy81 View Post
    You have to find the problem first. Check all pulleys and tensioners. Either the belt is moving around on a pulley or it is off all the time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: mysterious shredding belt
    Sep 2011
    west palm beach, fl
    Ok. I'll go have another look
  1. Mysterious dinging!?!?!
    By silverbullet10 in forum General Tech Discussion
    Last Post: 03-02-2014, 02:04 AM
  2. Mysterious Wire Help
    By Konner27 in forum General Tech Discussion
    Last Post: 11-23-2013, 03:43 PM
  3. mysterious connector!?
    Last Post: 08-09-2011, 02:00 PM
  4. Mysterious grind only while braking
    By techweenie in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2011, 07:06 PM
  5. mysterious clicking
    By bennybravo in forum General Tech Discussion
    Last Post: 03-06-2010, 01:07 PM
