Thread: Could use some suggestions.
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 68
  1. #1 Could use some suggestions.
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    So I'm wanting to get a bit more go-fast out of my GTP, but I aint worried about making it a monster, I have an old muscle car for that stuff.
    So I'm looking at getting the SLP headers: apparently the cheap ones on ebay are the same design? Are they of similar quality?
    If I were to get those headers, and do the intake bit with a K&N element, and the 1.9 roller rockers and a custom PCM tune, what would be the smallest pulley I could run safely (with proper plugs ofcourse)? I'm at basically sea-level if that makes any difference. I'm guessing a 3.25", 3.4 at least?
    Based on what i read on the sticky for safe modding, I'm going to leave my cat-back stock.
    Anyone with the special edition hood (I know more than just the 40th ann. edition came with the hood) able to give me any information on hood clearance and intercoolers, I'm currently thinking it a fullsize wont fit, but would like a confirmation either way.
    This is also assuming (from the reading I've done), that the mods list I listed above (headers, intake, rockers, 3.25 or 3.4 pulley, plugs) wont need an upgraded TB, MAF, injectors/pump, plug wires, or anything else? Any corrections would be appreciated!
    Thanks again
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  2. #2 Re: Could use some suggestions.
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    with headers and rockers you should easily be able to run a 3.4 .start there , scan for knock , if no knock get the next smallest...lather, rince, repeat.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #3 Re: Could use some suggestions.
    3.4 tops on the pulley unless you run corn or get a ic under the blower.
  4. #4 Re: Could use some suggestions.
    and you need it tuned.
  5. #5 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    I forgot to mention a 160ยบ thermostat, but I honestly think that should be a given, along with valve springs if someone says anything regarding valve-train.
    I was hopin to get an informed enough opinion to only have to buy 1 pulley one time and just be done with it, heh. Most of the packages I've seen on the various websites (intense, zzp, 3800) and what I read here have me almost convinced a 3.25 would be should be fine, but I'd rather measure twice and cut once.
    @ scottydogs, I plan on getting the pcm tuned, just gotta figure out what all I'm throwin at it first. I was hoping with the headers and 1.9 rockers i'd relieve heat/exhaust enough to safely do a 3.25", but if not then the 3.4 will be what I go with.
    If i were to intercool it, I'd go as deep as i could on the pulley and then get everything ported and get all the supporting fuel mods and in the end be better off having done a turbo lol, and if I'm going to drop that kind of money, I might as well do it to the car that should already allegedly be in the low 11's and make it even faster for cheaper.
  6. #6 Re: Could use some suggestions.
    forget the t stat, run a 195.
    i had exactly what your wanting. i still run a 195 with the fans tuned to 180.
  7. #7 Re: Could use some suggestions.
    Jan 2014
    AR
    If I were you I'd be looking for quarter mile times on different mild setups so that yeah, you only cut once and get it the right length so to speak. I've not paid much attention to HP mod threads as I don't plan any myself. But with the level of desire and capability your post suggests... I think I'd set my sights on a 3.4 and concentrate on fully tweaking the support mods so its safe to drive like you want. And drive the thumpy Buford often!
  8. #8 Re: Could use some suggestions.
    Kemmerer, Wyoming
    you wont need an upgraded throttle body or maf sensor, but the throttle response is nice if you switch to a northstar throttle body and maf sensor. if you do switch to said tb/maf you will need it tuned to adjust the maf table in the pcm. stock injectors are fine until to have a pulley smaller than 3.1". a custom tune is going to be the best bang for your buck. if you can afford to spend 500 or 679 on a tuner then pick up an HP Tuners and either learn to tune or have Will from Overkilled work with your scans to get it tuned. Good thing about HP Tuners is that it can tune a lot of different vehicles.
  9. #9 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    Quote Originally Posted by SgtMarshal View Post
    Can it tune my skylark?
    jk lol
    And thanks all for the input. It'd be really hard for me to justify dropping that much on a tuner, I know that I can get super involved here, with a wideband A/F sensor, blowoff valve controller, and a bunch of other stuff, and eventually I might actually get THAT involved in this car, but for now, due to monetary concerns (both for a part budget and the fact that the GP is my daily driver), I'm hopin to just get away throwin some bolt-ons at it and not getting too serious to get a decent jump in the power potential. Down the road, once I've got a decent career going, a 6.0L with a turbo or two and a 6T80E transmission is where I'd like to eventually go, but even that would be after I've gone with a fully aluminum 455 fuel injected build.
    Last edited by USonuMabeaCh; 09-15-2015 at 09:04 PM. Reason: bad grammar from editing
  10. #10 Re: Could use some suggestions.
    Kemmerer, Wyoming
    Quote Originally Posted by USonuMabeaCh View Post
    here is my opinion: I have an XP cam, ported heads, a full size intercooler and am running a 3.25" pulley. my car has kr when I go smaller. you will not be able to just buy one pulley and call it good, unless you are will to settle with a 3.5". you could probably run a 3.25" pulley if you did the headers 1.9 rockers and a methanol injection, but again tuning will be required.
  11. #11 Re: Could use some suggestions.
    Invest in a wideband aswell.
  12. #12 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    When you say tuning, do you mean like mailing my pcu and having it reprogrammed by someone with some know-how and a list of my mods, or a tuning session with my car on a chassis dyno all afternoon?
  13. #13 Re: Could use some suggestions.
    Kemmerer, Wyoming
    you can send your pcm to someone that will load a tune on it, but getting a chassis tune is going to be light years ahead. it doesn't have to be done in an afternoon on the dyno, if you get the hp tuners like I suggested, Will will get you started with an initial tune and then make adjustments based on the data collected from the scanner/tuner.
  14. #14 Re: Could use some suggestions.
    Dec 2014
    Maryland
    every car reacts differently to mods, so those mod to pulley formulas are all just ballpark baselines. one guy can run knock free on a 3.4 with just headers and 104's , while the next guy with the same car will get knock with headers , 104's , and rockers .... you don't know until you know.
  15. #15 Re: Could use some suggestions.
    you can buy a dhp tuner set up for 250. and learn to tune. lots of us here use dhp too. maybe more DHP users then the hp tuners.
  16. #16 Re: Could use some suggestions.
    I break stuff selliott's Avatar
    Kansas City
    Quote Originally Posted by EHBGoober View Post
    This
  17. #17 Re: Could use some suggestions.
    i was the latter guy 4.3ยบ kr with headers 1.95 rockers, and a 3.4. i tuned that out with dhp tho.
  18. #18 Re: Could use some suggestions.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    im in the same boat, what sort of 1/4 would the setup OP wants (with the 3.4) get?
  19. #19 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    @ 04lss: I'm assuming low 14's high 13's, maybe mid 13's at best..?
    @ the gurus: So, will I need a wideband AF gauge just for the tuning, or is this something I'm going to have to constantly monitor and mess with? If all else fails I'll try and find someone on these boards that's within a moderately reasonable drive of me and pay them to borrow theirs if I can get away with using it once.
    Anyone in the gulf coast region within a couple hours of Pensacola? lol
    So an AF ratio gauge, knock sensor, and the tuner, is there anything else I'd be stupid not to get?
  20. #20 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    BTW, are the SLP knock offs of similar quality to the SLPs?
  1. Looking for cam suggestions...
    By transam24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2013, 11:44 PM
  2. 2 new DTC's, need some suggestions
    By 06camarodude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:10 PM
  3. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  4. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  5. ok any suggestions?
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2009, 01:04 PM
