Thread: Could use some suggestions.
Results 41 to 60 of 68
  1. #41 Re: Could use some suggestions.
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    So which will I be using to read knock, the aeroforce, or the dhp?
    And where do I find 1.95 ratio rockers, lol.
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  2. #42 Re: Could use some suggestions.
    aeroforce aint cheap, but that stays in a gauge pod in the car and can scan all sorts of live data kr included.
    the t app is less than 20 bucks if you own a droid phone or tablet. it reads more live data than you'll know wtf to do with lol
    the dhp. the way you tune is to run a scan log aka scan. save it review it and make changes to the bin file as needed. it reads every thing the other two read but its more accurate. easy to save it, open it, use it to tune with.
  3. #43 Re: Could use some suggestions.
    the rockers, i heard a little bird say that gmr oldass has a set. shoot him a pm.
  4. #44 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    I might just do that, just wantin to know a little more about em... I'm just kinda nervous since none of the major websites sell em that big, they near the ceiling of safe range for the ratio or something? What kind of gain do they have over the 1.9's?
    I really appreciate all the help btw
  5. #45 Re: Could use some suggestions.
    not sure if theres much more of a gain, but i got em on my car. yt 1.95's oddly enough i got em from the same guy who i posted up there.
    they do need a washer under the pedestal and different push rods.
    when i first put them on i was all stock still. (im still pretty stock lol) they cleared up 5* kr right off the bat, no tuning. i had 8*.
  6. #46 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    Do the 1.9s need anything extra aside from springs?
  7. #47 Re: Could use some suggestions.
    Springs, retainers,locks and change the valve seals while your at it.
    04 Comp G.
  8. #48 Re: Could use some suggestions.
    some rocker porn.
    same rockers on the new engine.
  9. #49 Re: Could use some suggestions.
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Are the rockers a noticeable gain in power/acceleration? or is it an "it feels faster ... I think" sort of thing?
  10. #50 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by SgtMarshal View Post
    here is my opinion: I have an XP cam, ported heads, a full size intercooler and am running a 3.25" pulley. my car has kr when I go smaller. you will not be able to just buy one pulley and call it good, unless you are will to settle with a 3.5". you could probably run a 3.25" pulley if you did the headers 1.9 rockers and a methanol injection, but again tuning will be required.
    Wow you have a xp cam ported heads and fsic and your kr rises if you go lower? Injectors are the same? Or you upgraded? Im running 2.8 no knock with the same cam headers and a gen v with ported heads..can't understand that one
    Sent from my LG-D851 using Tapatalk
  11. #51 Re: Could use some suggestions.
    ^ the thing is..he didn't get his XP from me
    04 Comp G.
  12. #52 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Lol!! But . does he have e85? Must have a vac leak or something.. Not tryna question it or put crap in the thread.. Just saying i cant see a cammed icooled car only running a 3.2.. Knocking at times... With ported heads
  13. #53 Re: Could use some suggestions.
    Kemmerer, Wyoming
    Quote Originally Posted by jayroca View Post
    I have no idea what's wrong with it. I haven't been able to find a vac leak. did have an exhaust leak that is fixed now. I'm on 42 lb injectors and a northstar tb/maf. I'm planning a swap to 130 lb springs in the next couple months, so we will see what difference that makes. doing a double roller timing chain and a bigger harmonic balancer in the next month.
  14. #54 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Oh ok.. Not tryna tlk s**t just tryna figure why all those mods you have and its not allowing you to drop pulleys and you have every knock killer for the motor other then e85 ...
  15. #55 Re: Could use some suggestions.
    Kemmerer, Wyoming
    I understand. no offense taken. I am in the process of a custom turbo build, so I'm not real concerned about the big pulley.
  16. #56 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    What type of intercooler?
  17. #57 Re: Could use some suggestions.
    Kemmerer, Wyoming
    full size phenolic
  18. #58 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    full size phenolic
    Man ... I was thinking of grabbing one too!!! Hopefully u find the issue
  19. #59 Re: Could use some suggestions.
    Kemmerer, Wyoming
    with that build you have, a phenolic intercooler would support a 2.6 pulley. I have a 2.6 and the snout machining tool and I would let them go pretty cheap. pm me if you are interested.
    the phenolic works really well as far as I can tell. I put a temp gauge in the front mount heat exchanger, and it is stays at the lowest temp the sensor is calibrated for, 68 degrees F. I'm trying to decide if I care enough to know what the actual coolant temp is to buy an aeroforce coolant temp sensor kit, or just go with an air temp sensor in the lower intake manifold.
  20. #60 Re: Could use some suggestions.
    Banned
    Jan 2013
    maryland
    Im pretty sure i can drop to a 2.55 with tuning and that phenolic intercooler.. Along with the e85 that i have.. Im currently am on a 3.0 right now went up a size.. Id rather get the timing upped on in then to rag on it with 2.8.. If you ever think about selling the IC.. Im your guy lol
  1. Looking for cam suggestions...
    By transam24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2013, 11:44 PM
  2. 2 new DTC's, need some suggestions
    By 06camarodude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:10 PM
  3. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  4. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  5. ok any suggestions?
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2009, 01:04 PM
