Thread: Could use some suggestions.
Results 21 to 40 of 68
  1. #21 Re: Could use some suggestions.
    a lot of us run speed daddy headers, 200 shipped. cant beat em really for the price.
    tuning not a one and done type thing. best if its done over a few days time, as you need to let things learn before you scan and re adjust things.
    i use the torque app for daily eye ball scanning. nice and cheap, and the dhp for data logged scans.
    dont need a wideband but its nice to know for sure what your a/f really is. you can hook it up to the dhp unit and scan with it too.
  2. #22 Re: Could use some suggestions.
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    Quote Originally Posted by EHBGoober View Post
    every car reacts differently to mods, so those mod to pulley formulas are all just ballpark baselines. one guy can run knock free on a 3.4 with just headers and 104's , while the next guy with the same car will get knock with headers , 104's , and rockers .... you don't know until you know.
    to further prove my point. on my 2000 GTP i have a 3inch downpipe , zzp powerlog , 9 inch cone intake , AL 104 plugs. overkill tuned pcm . just put a 3.4 SC pulley on today . i seen as high as 8* of KR.
    another member, burbman has the very same setup on his 2001 GTP , but he has the zzp pcm and he is seeing less than 2* of kr.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #23 Re: Could use some suggestions.
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    Ok, so I did some more reading and I guess what I'm currently looking at, for now, is:
    SD headers
    1.90 rockers
    CAI
    genV blower
    N* TB
    modular pulley system
    aeroforce interceptor gauge + wideband o2 sensor
    tuner
    plugs and pulley determined by tune, assuming 3.4 and 104s
    1. do the SD headers go to the cat or will i still need to delete the Ubend/buy a downpipe?
    2. what all will I need to make the N* TB work?
    3. When people are talking LIM, is it just a gasket replacement?
    4. Anything I'm missing, either to lower KR or fill this build or anything i have that's superfluous?
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  4. #24 Re: Could use some suggestions.
    Kemmerer, Wyoming
    Quote Originally Posted by USonuMabeaCh View Post
    SD headers
    1.90 rockers
    CAI
    genV blower
    N* TB
    tuner
    SD headers should come with a downpipe, no need to worry about the u bend. for the northstar to work you will need an adapter plate to mount the tb to the supercharger, and will need tuning for it to work properly. if you switch to the northstar tb, you will also need the northstar maf. the LIM is the lower intake manifold, the piece that bolts the supercharger to the engine.
    I strongly recommend you stick with the copper tip 104's.
  5. #25 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    what exactly is it that needs to be done to the lower intake manifold? What I gathered from reading around was replacing the gasket, is that correct?
    As for the N*, I remember reading something about an ls7(?) MAF, and that I can port the blower housing so that the TB fits without the adapter plate?
    Would upgrading the motor mounts be a good idea?
  6. #26 Re: Could use some suggestions.
    SDs come with the downpipe so that takes care of the ubend.
    Lim = lower intake manifold.. Most either had or have those plastic gaskets go bad on them and leak so it's preventive maintenance to go ahead and change them for the aluminum style ones.
    Your off to a good start
    04 Comp G.
  7. #27 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    Quote Originally Posted by ScottyDoggs View Post
    you can buy a dhp tuner set up for 250. and learn to tune. lots of us here use dhp too. maybe more DHP users then the hp tuners.
    Im seeing that DHP is no longer in business, I'd prefer to go that route since it's a ton cheaper and doesn't have the pay to use bit. Does DHP have the kind of access to do everything necessary?
  8. #28 Re: Could use some suggestions.
    truth is, it can do more then then HP tuners can. you can use tiny tuner, its a bin editor program. has files unlocked that no one else has. like to kill a cat test for the 01 up cars. make a car with out perf shift have it in the pcm now working with a button you need to add.
    hp tuners is kinda like aol was, it holds your hand and has pretty graphs and stuff lol the end result is they both get the job done. HP is probably more user friendly tho.
  9. #29 Re: Could use some suggestions.
    Kemmerer, Wyoming
    you are going to need an adapter plate regardless of porting. the northstar tb has a different bolt pattern than the L67. you can upgrade the upper motor mounts to poly mounts so the engine is held firmer. there are two sets of upper motor mounts, the round ones that go in the dogbones and the square ones that go in the mounts. you can also upgrade the engine mount to a poly mount, which will also help to hold the engine firmer. I don't recommend changing the transmission mount to a poly mount as it causes a lot of vibration.
  10. #30 Re: Could use some suggestions.
    Kemmerer, Wyoming
    I started with a dhp and once I learned a bit, I sold it and bought an HP Tuners. the dhp is nice to have, but the hp tuners software is far superior to the dhp. the HP Tuners software just works, while the dhp doesn't just work as it is a process to get set up
  11. #31 Re: Could use some suggestions.
    vet never got his hp tuner synced up, lol dhp is rather easy once your told wtf to do, or you can pull your hair out. ive helped a number of guys set them up here. got screen shots and stuff t help out.
    the only support you get is off forums with active dhp users. and bills drop box of gold https://www.dropbox.com/sh/npa8brtuzoq3qps/jqYuBP0cv- dhp software, tiny tuner, bins from almost years supported, tuner manuals and so on.
  12. #32 Re: Could use some suggestions.
    Kemmerer, Wyoming
    vet hasn't been able to get his hp tuner to work? how is that possible? is so easy even a caveman could do it.
  13. #33 Re: Could use some suggestions.
    and he is a caveman lol last i heard it was still not running, dont know wtf he was doing over there. think he even offered to sell it with the turbo kits and stuff.
  14. #34 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    Scotty, what would I need to get my hands on to use that software, like the physical interace/hardware?
  15. #35 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    as for using a dhp, I'd rather go that route, simply out of cost... but I cant seem to find one. Hoping there might be a board member I can meet up with and maybe sort something out. My only other option is to buy a bunch of pulleys and go spend $500+ at a shop that's an hour away for a dyno tune. And i dont want to buy a bunch of pulleys just so i can figure out which ONE i need :/
  16. #36 Re: Could use some suggestions.
    you buy a new avt box and use the dhp software with it, you need to down load some firmware or some thing to it.
    http://www.grandprixforums.net/threa...VT-box-for-DHP
  17. #37 Re: Could use some suggestions.
    a 3.4 is the wall pretty much even if you toss a cam in there.
    unless your on e85 fuel, or get a ic.
  18. #38 Re: Could use some suggestions.
    Kemmerer, Wyoming
    just start at a 3.4" and see what happens. many people come on this forum to look for parts, so you should be able to recoup some of your money on the pulley.
  19. #39 Re: Could use some suggestions.
    Sep 2015
    gulf breeze, fl
    im making this a much bigger headache than it needs to be... I guess I'm going to pick up one of those avt things, see what I can do, and maybe eventually risk taking it to one of these dyno-tuning shops near here and hope they dont ruin my car because it isn't an camaro or mustang.
    PS: Scotty, where'd you get 1.95 rockers? Highest ive been able to find is 1.90
    Thanks everyone for all the inphomashunz
    last question.. will the aeroforce gauge be able to read knock, or is that what the DHP is for?
  20. #40 Re: Could use some suggestions.
    Dec 2014
    Maryland
  1. Looking for cam suggestions...
    By transam24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2013, 11:44 PM
  2. 2 new DTC's, need some suggestions
    By 06camarodude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 05:10 PM
  3. n/a gp gt need some suggestions
    By kyleheine298 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 12:26 PM
  4. cam suggestions?
    By 2000gprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2009, 12:39 PM
  5. ok any suggestions?
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-21-2009, 01:04 PM
