I've actually got a set of the FelPros that were intended for my GT, but never needed, they've been rolling around in the trunk of the GT for a good year now. So don't torque to spec, just snug and that's it?
you cant use those, they are not the same.
and just snug em. f the tq spec on those, they will snap.
i hear ya. no surprises are nice.
WTH? If you are snapping those bolts, your torque wrench is uncalibrated or cheap or you simply don't know how to use one.
Also, you don't really need to torque them, you can get away with snugging them. I just torqued mine for ease of mind.
Sent from my LG G3
i never broke one, but others have here. f tq spec, snug em.
Are you sure you're not projecting your past screw ups onto other members?
Sent from my LG G3
ive seen a number of threads with guys who snapped em off with a tq wrench. just snug em.
once again, ive not busted a single bolt on anything related to my car that matters.
cat back bolts dont count, nor do the cross over bolts on the stock manifolds, i was hoping more snapped off. only two snapped. lol
IDC what anyone says, whoever snaps them off with a torque wrench is doing something wrong.
You can never really count exhaust bolts for a reason on these cars.
I've stripped bolts that matter and snapped a bolt that goes to the coolant block off plate on the side of the LIM lol
Sent from my LG G3
the only thing i used a tq wrench on when i put the engine back together was the heads, and the crank sensor. thats it. every thing else got snugged good and a 1/4 to a 1/2 turn more tops.
Let me ask you something, did you use the torque wrench or a breaker bar to tighten the additional 90 degrees? IIRC it's 90*
Sent from my LG G3
breaker bar, mr breaks bolts lol
why would i beat the hell out of calibrated tool?
and the last 30º on the top row is the real b1tch. lol
its not that hard, but its super tight, like it feels like the bolts are gonna snap. keep in mind, my way to make a bolt tight is good and snug and a 1/4 turn more. so cranking on them bolts is a un easy feeling to me.
i even had a degree thing. 10 bucks on the peg board back in its box like its new. who knows if ill ever need it again.
Exactly! After doing several different engines, I learned not to worry too much because if the bolt snaps, you know it's the bolts fault provided your tools are calibrated and you have the right specs.
It must be a real b!tch to drill out a broken head bolt tho lol
Sent from my LG G3
Well. Everything is almost back together before it got dark. All that's left is alternator, evap stuff, oil change, vaccuum lines and some other miscellaneous stuff.
Couple quick questions. Do any of the following need a torque spec? Idler pulley, tensioner, coil bracket, throttle body.
nope, make em tight, but dont over do it. i like to make bolts good and snug, then 1/4 turn more depending on the bolt thickness.
Awesome thanks!
Did you flush the valley with oil, or did you drain almost all the coolant before removing the LIM?
I spilled some coolant so I ended up flushing the valley out.
