Thread: Rebuilding L67 motor
Results 1 to 17 of 17
  1. #1 Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    I am rebuilding a L67 and I was wondering if I should get new piston rings and where is the cheapest if so? Does everyone buy new rings? Thanks for the help!!!!!!
  2. #2 Re: Rebuilding L67 motor
    TDCRacing
    Guest
    Yep new rings ,cam bearings, Rod bearings, Main bearings, Needs to be line honed,the cylinders need to be honed and probably would not be a bad Idea to also get the machine shop to deck it.
    You may be better off getting a used one.
    I would like to rebuild one just for the experience in doing so on a 3800 motor.
    You can get rings from you're parts store or ZZPerformance.
  3. #3 Re: Rebuilding L67 motor
  4. #4 Re: Rebuilding L67 motor
    TDCRacing
    Guest
    Quote Originally Posted by TDCRacing View Post
    For sure.
  5. #5 Re: Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    Nah I have a block already I just wanted to know if I should replace the rings.
  6. #6 Re: Rebuilding L67 motor
    do a compression test on it and see if it leaks down badly.
  7. #7 Re: Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    I already have the block stripped bare. It goes to the machine shop tomorrow new cam bearings and main bearings are going in and the XP cam lol!!!!!
  8. #8 Re: Rebuilding L67 motor
  9. #9 Re: Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    yea I am just ready to get in the car lol
  10. #10 Re: Rebuilding L67 motor
    I live here. UR LOSN's Avatar
    Rockford, IL
    new pistons would be ideal! rods hold up to anything! ever think about cryo treating the rods and crank? will add a crap load of strength!!!!!
  11. #11 Re: Rebuilding L67 motor
    TDCRacing
    Guest
    [QUOTE=UR LOSN;134891] rods hold up to anything! QUOTE]
    No they don't
    lol
  12. #12 Re: Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    pistons are still good I am getting new rings for them.
  13. #13 Re: Rebuilding L67 motor
    Moore, Oklahoma
    If your planning to go cammed (which i see you are) i'd definately build it right and go with some forged slugs. You might also consider increasing the size of your oiling ports on the bottom end.
    Shawn W. Larsen
  14. #14 Re: Rebuilding L67 motor
    May 2008
    staten island,NY
    why would you buy a used motor and not go into it is beyond me? i bought a used L32 from Ed and i still had it rebuilt. the car it was taken out from had 80k on it and the guy never changed the oil. there was so much carbon build up on the pistons etc.
  15. #15 Re: Rebuilding L67 motor
    Nov 2008
    Burkburnett, Texas
    I am getting everything new except pistons and rods but they are getting cleaned up and new rings. I don't need forged slug to just put a cam in.
  16. #16 Re: Rebuilding L67 motor
    forged internals wont take much more of a beating than regular ones if youre just going to let it slide because "you have forged internals". you still have to have the car running well.
  17. #17 Re: Rebuilding L67 motor
    Moore, Oklahoma
    Forged pistons are stronger without a doubt. 3800 Series 2/3 pistons are quite weak when making some power.
    No, you don't need forged slugs with a cam. But down the road you'll probably want more and push your setups to the limits. The forged will undoubtably take more abuse (within reason) than the stock hypers ever will. Why build it now and redo it later? Might as well cover all the bases now, but thats just me thinking ahead.
    Figured i'd point that out so you can look at your options. For the time and trouble, i'd get the forged slugs for the thicker ring landing alone. Not to mention the added strength.
    Then again, no one chips pistons I suppose...
    Shawn W. Larsen
  1. wiper motor
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-08-2011, 01:19 PM
  2. Motor Swap
    By Rolling89GPSE in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-26-2010, 05:09 PM
  3. Motor oil for 3800?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 07:04 PM
  4. The motor out of the Z26
    By Zach3800 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2008, 01:12 AM
  5. will a 03 gtp motor work in a 98 gtp????
    By gtpmadman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 11:05 AM
