Thread: vacuum leak test
Results 1 to 4 of 4
  1. #1 vacuum leak test
    Sep 2012
    Philly
    I am having a problem with a high idle with my 2000 GTP, I checked the IAC and that is OK so I think
    I may have a vacuum leak somewhere. the vacuum lines are all good and have no leaks. What should
    the vacuum reading be at idle after the engine is warmed up and where should I get the reading from.
    Should I get it from the front of intake or at the T on the top of the supercharger.
    Thanks
    Mark
  2. #2 Re: vacuum leak test
    spray some carb cleaner at the vac lines, if the idle jumps you found your leak area. move the lines around if you find nothing the first time round.
  3. #3 Re: vacuum leak test
    I hate carb cleaner, it just bogs the motor. Thats why it'll never start with that crap if you spray it in the intake. Use brake cleaner instead.
    But you'd have to have some huge vacuum leak to notice an rpm jump, easier to just watch fuel trims. If they change when sprayed, you've found the leak.
    Normal intake manifold pressure/vacuum is normally around -19 to -20in/hgs. And fuel trims on the LONG TERM within 5% of zero, if they read +16.4 you have a vacuum leak somewhere.
  4. #4 Re: vacuum leak test
    carb cleaner made my idle fly up when it hit the busted vac line i had. only the lines crack was closed with its weight on in, so lifting the lines and spraying made it show its face.
    starting fluid will also work if you got that on hand.
  1. Vacuum leak
    By Kellson in forum General Grand Prix Discussion
    Last Post: 02-28-2014, 01:28 AM
  2. Vacuum Leak?
    By Oilcan in forum Engine
    Last Post: 11-03-2013, 09:00 PM
  3. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  4. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  5. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
