Thread: Rockers vs Headers ?
Page 1 of 3 123 LastLast
Results 1 to 20 of 56
  1. #1 Rockers vs Headers ?
    SE Level Member kewGTP's Avatar
    Mar 2015
    Appleton, WI
    So I plan on doing both eventually with a intercooler setup. . . however, I only have such much $$ to do one upgrade at a time, so my question is which upgrade would be better for lowering KR and increasing performance? I am leaning towards rockers (1:9) just for ease of install.
    '05 GTP - E85 - XP Cam - 3.0 Pulley - Supporting Mods...
  2. #2 Re: Rockers vs Headers ?
    Mar 2012
    NC
    Do headers first. The 1.9's won't have much flow benefit through stock manifolds.
  3. #3 Re: Rockers vs Headers ?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Headers need to come first.
  4. #4 Re: Rockers vs Headers ?
    Buffalo
    Headers / downpipe
  5. #5 Re: Rockers vs Headers ?
    rockers killed off 5* of KR on my car. a simple u bend delete took the other 3* of KR away.
  6. #6 Re: Rockers vs Headers ?
    Aug 2013
    McDonald PA
    Quote Originally Posted by Sven The Baldman View Post
    Took the words right out of my mouth
  7. #7 Re: Rockers vs Headers ?
    so how did i loose 5* of kr after installing them? you guys......
  8. #8 Re: Rockers vs Headers ?
    Your old and lose things all the time?
  9. #9 Re: Rockers vs Headers ?
    if we all just lost KR tho. lol
  10. #10 Re: Rockers vs Headers ?
    Jul 2012
    Chicago
    Rockers give benefit, even on stock manifolds. But they'll give a bigger benefit with headers. Just a logical progression.
    -Carl
  11. #11 Re: Rockers vs Headers ?
    rockers, headers and a 3.4 is a nice bump over stock. thats for sure.
  12. #12 Re: Rockers vs Headers ?
    Mar 2015
    Appleton, WI
    Thanks guys, looks like headers/downpipe are gonna be the next upgrade. Is it safe to say that the ZZP headers are good or are there other recommendations?
  13. #13 Re: Rockers vs Headers ?
    speed daddy headers are 220 shipped and work just as well.
  14. #14 Re: Rockers vs Headers ?
    ZZP's would be the top "grade" of headers. Least amount of issues, no extra parts to buy, no denting the firewall.
  15. #15 Re: Rockers vs Headers ?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    Do you think they're worth the extra money?
  16. #16 Re: Rockers vs Headers ?
    May 2008
    Schuyler, NE
    Headers suck. I would do rockers.
  17. #17 Re: Rockers vs Headers ?
    I love my ZZP headers... had to ef with the dip stick a little but I eventually got it in there (giggity)
  18. #18 Re: Rockers vs Headers ?
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Do the speed daddy headers. You have an 05? On my 04 the fit wasn't that bad. And it took my knock from like 5+ stock, to 0-1. When I added a 3.5 it went back to about 2-3, but the power increase was worth it.
    Do the headers then down the line, do your lim (if you need it) and throw some VC gaskets and rockers/springs on it.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  19. #19 Re: Rockers vs Headers ?
    Mar 2015
    Appleton, WI
    Any quality/fit complaints on the speed daddy headers? I was leaning towards the ZZP headers, but saving $400 is hard to look past.
  20. #20 Re: Rockers vs Headers ?
    Kemmerer, Wyoming
    I didn't like how the downpipe dipped down, some people say its fine, but I cut the flex section out and welded in a shorter flex section to fix it. also, your front o2 sensor wire harness will need to be lengthened. the clamps that come with the speed daddy headers sometimes leak, so try them out and if they dont leak then thats a good deal, otherwise you can pick up a band style clamp that should fix the leak.
  1. headers or roller rockers?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 06-16-2013, 09:49 AM
  2. Wtb headers and 1.9 rockers with springs
    By Adam D in forum Wanted To Buy - Parts
    Last Post: 02-04-2013, 06:19 AM
  3. 1.9 Rockers or Headers?
    By SliceTheRice in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 11:42 PM
  4. headers, rockers n stuff
    By EmEaston24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 05:01 PM
