Oh with oil 5k should be fine, I use something different. Sorry I'm half asleep and didn't read right.
the dealer told me the scheduled interval on oil changes for my 2014 Cruze is every 7500 miles, and that get's a synthetic blend. I'm trying to decide if its worth swapping from the synthetic blend to a full synthetic and change the filter every 7500 miles and oil every 15,000
Well IK the 97-03 generation is 5k mileage intervals on regular oil but I'm not sure on 04+. I heard 7,500 miles but IDK if thats true.
So I will be good on 5k then?
I highly suggest not going over 5k on a 1.4T.
Smell the oil when it comes out and feel it, the turbo gets that oil so damn hot. It's burnt and nasty after 5k even with the best Dexos valvoline oil we sell at my work.
Only time I've ever used full synthetic was because the kid at the counter insisted VR-1 was ALL synthetic. So I got one oil change for the flat tappet car in synthetic at conventional price. I liked it. In my daily GTP, I use a blended oil and go 3,500-4000.
Time frame? 6 months?
I used this Royal Purple & was strongly advised not to, so I then went to Mobile 1.http://images.tapatalk-cdn.com/15/08...d31fc18ab2.jpghttp://images.tapatalk-cdn.com/15/08...3b21a106fd.jpg
Oil is oil, synthetic is synthetic.
Valvoline to Mobil 1 to Castrol, the motor will not know any different and they all must meet the same exact standards to be ran in a newer cars that call for dexos or whatever else. Cold weather testing is not something I will get into as certain oils do flow better at those temps but thats not what is important.
Your Cruze 1.4T can run the semi synthetic oil because it likely has or meets the dexos requirement that GM wants. Because it's turbo'd and the fact that they get so damn hot, I would change to a full syn just for that reason. A longer lasting oil is what I would want to run.
