is there enough benefit from running a 1.6 ratio yella terra roller tip rocker with ported L32 heads, 130 lb valve springs and an XP cam to justify the cost? in the future I'm going to be swapping out the 90 lb valve springs for 130 lb springs, so it won't be extra work, just not sure if its worth the 500 bucks extra.
