Thread: Belt tensioner question
Results 1 to 8 of 8
  1. #1 Belt tensioner question
    Aug 2015
    Florida
    Hi there, my 2006 Grand Prix supercharger 2 belt tensioner is whacked and I'm going to replace it. On Advanced Auot web sites they have two different types of tensioners. one is this
    http://shop.advanceautoparts.com/p/c...belt+tensioner
    and the other is this http://shop.advanceautoparts.com/p/l...belt+tensioner
    does this car have two tensioners ? which one do I need. Thanks
  2. #2 Re: Belt tensioner question
    Apr 2015
    Columbus, OH
    Which one is bad? The first one is your accessory loop. The second is for the supercharger. Yes, you have one of each.
    Top Swapped 01 Imp
  3. #3 Re: Belt tensioner question
    Aug 2015
    Florida
    oh ok. its the one that has the same belt as the supercharger. when I press on that belt I hear popping noise.
  4. #4 Re: Belt tensioner question
    its this one then http://shop.advanceautoparts.com/p/l...=27795&irgwc=1
    and damn thats a lot. add a code for sure. or hit a junk yard for cheap parts.
    inside the tensioner is a nut. its a 13 mm. but not all deep sockets fit. i find a 12 point 13 mm fits perfect. kobalt brand.
    some have ground down the out side of the socket to make it fit. thats the only hang up changing it.
    and a popping noise dont really mean its bad, it could be the pulley on it, and its change able for 20 bucks. take the belt off spin all the pulleys by hand, they should spin free and smooth.
    when a tensioner is bad they bounce like mad at idle. you also have wear indicator marks on it, you look at it from the top and side to see the marks.
  5. #5 Re: Belt tensioner question
    Aug 2015
    Florida
    Awesome. Thanks for clarifying. Do you know if anyone has any pics on here for replacement ?
  6. #6 Re: Belt tensioner question
    it slides off the stud, not much to it. note the angle its on there, theres this little notch that holds it in place. just take a pic before you take it off, you'll be fine.
  7. #7 Re: Belt tensioner question
    Aug 2015
    Florida
    Ight. Thanks !!!!
  8. #8 Re: Belt tensioner question
    Aug 2015
    Florida
    is this also the belt that goes to that tensioner ? http://shop.advanceautoparts.com/p/c...7-P#fragment-2
  1. '04 Belt Tensioner Install - Parts Question
    By robinsone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2015, 11:30 AM
  2. S/C belt tensioner
    By Tsimms55 in forum Wanted To Buy - Parts
    Last Post: 09-12-2014, 10:42 AM
  3. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  4. Tensioner Pulley/ Belt install question
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 04-22-2011, 06:48 AM
  5. belt tensioner
    By shawnz90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2009, 06:29 PM
