Thread: issues after harmonic balancer replacement
Results 1 to 4 of 4
  1. #1 issues after harmonic balancer replacement
    SE Level Member skafreakGTP's Avatar
    May 2015
    Sacramento CA
    Howdy everyone i just recently replaced the harmonic balancer on my 04 gp gtp and now she cranks but wont start, before i replaced the balancer she started up in a heartbeat with no issue, any clue on whats going on here? The only thing i can think of is there might be something wrong with my crankshaft sensor? Im stuck here so any help would be very much appreciated
  2. #2 Re: issues after harmonic balancer replacement
    Jul 2014
    New Jersey
    Did you line it up perfectly with the keyway, if not timing is off and your keyway is probably fuucked
  3. #3 Re: issues after harmonic balancer replacement
    if you didnt line up the key way you need t take it off again and pull out the busted key then replace it.
    why did the balancer come off in the first place?
  4. #4 Re: issues after harmonic balancer replacement
    Dec 2012
    Where 4T65E's were born
    Or the teeth on the balancer were bent that the crank sensor uses to determine engine speed.
    Third possibility is its not on all the way
    Sold.
  1. Harmonic balancer
    By dezebe1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2014, 10:19 PM
  2. harmonic balancer issues
    By lbzclint in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-20-2013, 03:29 PM
  3. cps and harmonic balancer replacement problems case learn needed?
    By nick121320 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2013, 08:44 AM
  4. Well there goes my L67 harmonic balancer...
    By jlgp2007nc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2013, 02:44 PM
