Thread: Traction control ABS activates randomly
Results 1 to 6 of 6
  1. #1 Traction control ABS activates randomly
    SE Level Member cooper15's Avatar
    Jul 2015
    This may be in the wrong forum sorry but I have a 07 grand prix gt 3.8. It randomly reads traction control ABS active for a few seconds every few minutes and can feel it activating. Then everyone in a while it says service abs system for a few minutes then reading goes away . What could this be?
    Sent from my SM-N910V using Tapatalk
  2. #2 Re: Traction control ABS activates randomly
    A handful of things without knowing if the system has thrown any codes.
    I'd just start by inspecting all wire harness's leading to each hub and cleaning the connectors and applying electronic grease to the sockets to prevent any issues with those connections.
  3. #3 Re: Traction control ABS activates randomly
    if you cant find any of what he said wrong^^^^^^ get it scanned at a shop for abs codes, or your just tossing money at it by guessing with new parts.
    a 07 may show some abs codes on a normal code scanner. most of the time you need a abs scanner tho.
  4. #4 Re: Traction control ABS activates randomly
    SWPA
    Quote Originally Posted by ScottyDoggs View Post
    The code reader at Advance spit out where my problem lied in the ABS on my 07 when I had a broken wire.
  5. #5 Re: Traction control ABS activates randomly
    Nov 2012
    Madison
    And make sure all your tires are equal psi
  6. #6 Re: Traction control ABS activates randomly
    Mar 2015
    USA
    ABS wheel sensor harness on the fronts. $20 something each from Rockauto
  1. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  2. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  3. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
