Thread: Looking for Throttle Body Alternatives
Results 1 to 3 of 3
  1. #1 Looking for Throttle Body Alternatives
    SE Level Member bobeebob's Avatar
    chicago
    Hey everyone, long story short I am trying to put a L67 from a 1998 bonneville with a Gen V m90 into a 2000 camaro.
    My biggest roadblock so far is that the camaro is drive by wire. For now I was going to use the camaro
    throttle but the bolt pattern is different than the bonneville.
    So my question is what throttle body I can use in this situation?
    I was going to try and use the L32 throttle body but the connecter has 13 cables going to it
    opposed to the 8 cables on the camaro harness.
    My next guess was going to get a hold of a Ls2 throttle and try to adapt the 6 cable connecter to work with the 8 cable on the camaro.
    Any ideas or suggestions are much appreciated.
    Thanks!
    Silver Turd - 1998 ssei XP cam, Gen V, 3.8 pulley, 3.29 gears, intense mail order tune
  2. #2 Re: Looking for Throttle Body Alternatives
    whatever tb you use will need an adapter plate.
  3. #3 Re: Looking for Throttle Body Alternatives
    Use an L67 throttle body from a 99-03 supercharged car. Best factory TB design. ZZPerformance sells the adapter plate. You'll have to cut up the GenV quite a bit anyways since the blower is longer than the GenIII.
    I'd honestly use a GenIII, so you don't need an adapter plate...and then you have plenty of templates from people that have added the 90* or more elbows on the back side of the supercharger. Not to mention the wiring is much easier, infact most of the sensors are direct swaps if I remember FBody's right. You can port the factory TB, and it'll be plenty of airflow for you, regardless of the setup. Especially if you're sticking with a blower and not tossing a turbo on.
  1. Detaching and Reattaching Throttle Cables to L67 Throttle Body
    By komrad36 in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2017, 12:09 PM
  2. ls1 throttle body help
    By gunsn88 in forum General Grand Prix Discussion
    Last Post: 01-25-2012, 11:44 PM
  3. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
