Ok i have a 2004 grand prix gtp and my ac compressor kicks in when it wants.. Ive change my pressor switch..ive changed the cord to it. Ive changed my dryer and refilled the freon... Ive traced the wire from the compressor all the way to fuse box.. Ive checked fuse relays amd the one diode... Ive also change my heater/ac switch inside my car.. Now heres what it does... If i leave my car run about 10 min at idle with my ac switch on sometimes it will kick on... Other then that the green wite from the compressor i can jump a wire from that to positive on battery and it kicks in... As soon as it kicks on i can disconnect that jumper wire and the compressor will stay working... Even if i **** off the switch in the car it will turn off and on when i hot the switch.... But if i shut it off for 10 min or so or shut the car off the ac is back to not workin... So ill either have to wait 10 min or so with car at idle or jump the positive wite and then remove the jumper wire and it will work.... Ove had it tested it has the right amout of freon and doesnt have high pressure... My question is what else could possible not sending it the power when i hit the button... Bc im gettin stumped on this....... Thanx in advance
