Thread: need some advice...
Results 1 to 14 of 14
  1. #1 need some advice...
    GT Level Member Dustoff's Avatar
    Mar 2014
    Canada
    So i decided to do my headers... well not suck a great ****ing experience..... broke one stud off during removal (yes its in the head) then snapped another one off tightening the new header in right beside the first one.... any ideas on getti g these lil ****ers out?!?!? Plasmas help!!!!
  2. #2 Re: need some advice...
    A clean/flush break or is there anything sticking out???
    If some is left, I would heat that sucker up with some map gas and use some vise grips to try and removed the rest.
    Or you could try welding a nut (weld inside the nut) to the rest of whats left and see if it will come out.
  3. #3 Re: need some advice...
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    what fdp said and a easy out might work if its a flush break
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: need some advice...
    Mar 2014
    Canada
    Damn. Both of them Broke off inside with nothing sticking out. I hate to try drilling it but i think a tap and die is the only way i can get em out. Judt scared to do it cause i did this once on ny old dodge truck and hit a water jacket... gotta be done tho i guess.
  5. #5 Re: need some advice...
    GXP Level Member
    Mar 2015
    Tomball
    Just make sure to use a left hand thread tap and drill. There is a product called Aldeen ease out and I find it works great for small things but have never used it over 5/16" sized studs. They sell a set at Home Depot it's about $19 a set but it's the only one I have had real luck with. The twist in and square ease outs seem to be crap.
    Jeff
  6. #6 Re: need some advice...
    and a right angle drill so you can get the bit to the busted bolt in the head easily.
    that really sucks.
  7. #7 Re: need some advice...
  8. #8 Re: need some advice...
    Apr 2015
    Columbus, OH
    Broke off in which head? If rear one I feel sorry for you.
    Top Swapped 01 Imp
  9. #9 Re: need some advice...
    Mar 2014
    Canada
    Thank god they r both in the front on the far right studs of the head from looking down at it. Im going to go buy a welder and try the nut approach first... the if that doesnt work i will be tappin her!
  10. #10 Re: need some advice...
    id try a easy out first, if that fails try the welder trick.
    did they break on the way in or out?
  11. #11 Re: need some advice...
    GXP Level Member
    Mar 2015
    Tomball
    This style is the ONLY eazy out I have ever been able to get a stuck bolt below flush out, and I have tried them all.
    http://www.homedepot.com/p/Ontel-Spe...0264/205110987
  12. #12 Re: need some advice...
    Mar 2014
    Canada
    One busted on removal and one busted going in. Lol i just want a reason to go buy a welder... i guess the easy out would be alright to try out.
  13. #13 Re: need some advice...
    GXP Level Member
    Mar 2015
    Tomball
    Make sure to use some Kroil or the penetrating lube of your choice.
    Jeff
  14. #14 Re: need some advice...
    Mar 2014
    Canada
    Awesome! Thanks for the tips everyone. Going to tackle this after the weekend camping trip.
  1. Need E85 advice please
    By Ultra440 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2012, 07:09 PM
  2. PCM advice
    By JimW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 09:46 AM
  3. new..99 GTP.. Advice???
    By hcokiid18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 11:19 PM
  4. Advice please
    By 40mphGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2010, 02:43 PM
  5. Need some advice
    Last Post: 02-20-2010, 08:49 PM
