View Poll Results: Which plug should i use ?
Voters
1. You may not vote on this poll
  • NGK TR55
    1 100.00%
  • NGK TR6
    0 0%
Multiple Choice Poll.
Thread: Which Plug should i go with ?
Results 1 to 10 of 10
  1. #1 Which Plug should i go with ?
    GXP Level Member ryangtp89's Avatar
    Maine
    The TR55 or The TR6 i asked both zzp's coustomer service and 3800performance's coustomer service both gave me a different heat ranges. So heres my mods list.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback,
    3.4mps, al 104's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: Which Plug should i go with ?
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    the tr55's are recommended for GT's while the TR6's for GTP's. I think the zzp site even says that.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: Which Plug should i go with ?
    Nov 2008
    Searcy,Arkansas
    My 07 it is SC came stock with NGK TR55.
  4. #4 Re: Which Plug should i go with ?
    Feb 2008
    South Bend, IN
    From zzp:
    "The TR55 is recommended for GTs. It can be used on near stock GTPs but we recommend a colder plug for boosted applications.
    The TR6 is our most popular plug. It is well suited for 3.4" pulley'd Grand Prix. This plug will give you full mileage and doesn't require any special precautions for use."
  5. #5 Re: Which Plug should i go with ?
    Aug 2008
    Flushing/Flint, MI
    keep the all 104 becaause the NGK are no better
  6. #6 Re: Which Plug should i go with ?
    Feb 2008
    South Bend, IN
    the ngk's are iridium right? those are supposed to last a little longer than the all copper plugs (autolite).
  7. #7 Re: Which Plug should i go with ?
    Maine
    Idk i heard around that the ngk last a bit longer than autolites.
    The ngk's do have iridium plugs just like autolites have them too, but the ngk iridiums are called TR55IX all the way to TR8IX They last longer than the coper but you cannot really gap them because the tip is too delicate for the gap to be changed.
  8. #8 Re: Which Plug should i go with ?
    Aug 2008
    Long Island, New York
    Our cars respond best to Autolite's... go with Autolite 104s. they are your best bet
  9. #9 Re: Which Plug should i go with ?
    Maine
    well they dont seem to last long. But i might buy them again along with PRJ wires and just for the hell of it i'm gonna buy new coil packs stock of course.
  10. #10 Re: Which Plug should i go with ?
    Feb 2008
    South Bend, IN
    what is the out of the box gap of the ngk iridium plugs?
  1. What Plug/Gap
    By RustyVette98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2008, 06:31 PM
  2. Quick plug ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 12:12 AM
  3. Plug Wires
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 11:56 PM
  4. I need this plug....
    By duane9586 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2008, 04:12 PM
  5. Anyone know where this plug goes/what it is???
    By LowlyfeGTP in forum General Tech Discussion
    Last Post: 01-23-2008, 04:35 AM
