Thread: 2005 gtp transmission cooler what should i buy?
Results 1 to 10 of 10
  1. #1 2005 gtp transmission cooler what should i buy?
    SE Level Member James8026's Avatar
    Feb 2015
    Michigan
    Sent from my DROID X2 using Tapatalk 2
  2. #2 Re: 2005 gtp transmission cooler what should i buy?
    Feb 2015
    Michigan
    My trans is running warm now that the warmer weather is here and i want to install my own cooler preferably with an electric fan. Anyone done this? Any advice or tips or dont forgets?
  3. #3 Re: 2005 gtp transmission cooler what should i buy?
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    I'm in the same boat. I spoke to Dave at TEP, and he said that he can build a custom standalone cooler similar to the one he builds for the GXP guys. My lines leak, so a stand alone kit that replaces all of the stock cooling lines would work great for me. I doubt a fan is needed.
    The GXP Kit:
    http://shop.tripleedgeperformance.co...TC4920-LS4.htm
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  4. #4 Re: 2005 gtp transmission cooler what should i buy?
    Feb 2015
    Michigan
    Seems a lil expensive i know its custom built but will it do any better than the one i found for $110 on google with a fan. Even if i dont need the fan its nice to have especially when im rodding on it
  5. #5 Re: 2005 gtp transmission cooler what should i buy?
    Hayden 1405 cheap and effective.
    A pan drop/shift kit and cooler should cool it plenty enough.. A fans not needed if it gets the hot still... You have bigger problems to worry about.
    04 Comp G.
  6. #6 Re: 2005 gtp transmission cooler what should i buy?
    Feb 2015
    Michigan
    Shift kit from where
  7. #7 Re: 2005 gtp transmission cooler what should i buy?
    Buffalo
    Personal preference. The intense kit was amazing IMHO
  8. #8 Re: 2005 gtp transmission cooler what should i buy?
    GTP Level Member
    Aug 2012
    st louis park, MN
    http://www.amazon.com/Transgo-T84167...hift+kit+4t65e
    I believe this is less aggressive than the intense but many have used this. Just look at the ratings.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  9. #9 Re: 2005 gtp transmission cooler what should i buy?
    Buffalo
    Didnnt Dave use intense kits in his builds?
  10. #10 Re: 2005 gtp transmission cooler what should i buy?
    SWPA
    Fan is definitely not needed.
    Temp said 86* outside today and highest trans temp I saw was around 180*. I am not even running standalone, I'm in series. If running stand alone it would be even cooler.
  1. *HOW TO* LS4 Transmission Cooler Install
    By DirtDog in forum 5.3L V8 (LS4)
    Last Post: 08-09-2015, 09:32 PM
  2. transmission cooler
    By bryanrhoads77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2014, 08:11 AM
  3. Transmission Cooler
    By nukkinfuttz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-14-2012, 07:33 PM
  4. transmission oil cooler
    By 03buickregalls in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 09:11 PM
