Thread: Still leaking LIM (fixed)
Results 1 to 9 of 9
  1. #1 Still leaking LIM (fixed)
    Charles City, IA
    I guest replaced the gaskets with the newer metal ones and now I have a new leak. It is the front right corner of the intake. It is -25 now, so I do not know if that is effecting it or not. Coolant also appears to be running up the bolt. I am going to pull the intake again and have a look. Any suggestions would be greatly appreciated.
    SMGPFC Two Nipple General
  2. #2 Re: Still leaking LIM
    you need to put RTV in the cornors where the sides meet. this will keep it from leaking.
    other than that just make sure youve got the right tightening order.
  3. #3 Re: Still leaking LIM
    Charles City, IA
    We put RTV on the corners, maybe just not enough. I followed the tightening sequence and torque spec. The only thing I can think of is I accidentally skipped a bolt. Put it on at 2am.
  4. #4 Re: Still leaking LIM
    hm..youre sure it's leaking from the lower intake then? did you let the RTV settle?
  5. #5 Re: Still leaking LIM
    Charles City, IA
    RTV settled for probably an hour and a half. There is a puddle of coolant around the bolt I guess It could be coming from the coolant o ring on the top of the intake.
  6. #6 Re: Still leaking LIM
  7. #7 Re: Still leaking LIM
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    Man that sucks....You have been having a ***** time with this....Look at it this way, you have a very good knowledge of the LIM now....
  8. #8 Re: Still leaking LIM
    Charles City, IA
    Figured it out today. Wow i'm dumb. I never looked at it with the car running. The thermostat housing was not tight enough and I could watch the coolant bubble out. She's all fixed up now. Finally lol! I also got ambitious and replace my stripped battery terminal bolt and my diverside fog light bulb.
  9. #9 Re: Still leaking LIM (fixed)
    Oklahoma
    glad to see you got it figured out and it wasnt a major issue and an easy fix.
  1. *FIXED* DRL issue...bad diode
    By alacran in forum General Tech Discussion
    Last Post: 07-21-2012, 11:53 PM
  2. Can this be safely fixed?????
    By YoungGTP in forum Visual/Body Modifications
    Last Post: 11-10-2008, 11:24 AM
  3. Never Got It Fixed
    By offroadfury6 in forum General Tech Discussion
    Last Post: 10-02-2008, 06:07 AM
  4. P0305 and P0401 96 3.1L Fixed
    By alacran in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-13-2008, 08:49 PM
