Thread: ...So pulling out the engine & trans
Results 1 to 20 of 22
  1. #1 ...So pulling out the engine & trans
    SE Level Member krysp432's Avatar
    Sep 2012
    Andrews Tx
    Whats up? OK so first off i posted last year with help dealing with my car, let me apologize for not updating. The car had a vacuum line that's why it wouldn't turn. But that was the least of my problems. I had my '12 Tundra stolen the following week...got her back, Thankfully! But thanks a bunch! for all the help from you guys.
    So back to the topic, im pulling out the engine and trans for a complete rebuild. Here's the question. I have done extensive research on the route I want to take. I would LOVE to drop a CAM, IC, GEN V, N*, but I'm scared of the drivability issues. What I'm aiming for is being able to get in her and drive for 12hrs without any problems.
    This is the plan.
    2004 Chevrolet Impala SS 3.8 L67
    SD Headers
    1.9 Rockers
    Lifters & Springs? (Don't know if needed or upgrade while I'm here)
    Port & Polish LIM, SC
    Spark plug Wires
    CAI
    N* TB? (Would it be worth?)
    CAM?
    IC?
    GEN V?
    Alum pan & valve covers
    Is there anything else I missed that needs to be considered while the engine and trans is out? Money is not an issue, been saving, but I just want to get the most out of my engine HP wise without ruining drivability(isn't everybody?) Again, sorry for sound such a noob. I understand that stock rockers with custom cam, probs with SD headers, etc.
    TIA
  2. #2 Re: ...So pulling out the engine & trans
    Buffalo
    There is ZERO drivability issues with a s1x/xp cam
    i can only think of 1 or 2 mods that would
  3. #3 Re: ...So pulling out the engine & trans
    Dec 2013
    ohio
    Unless you have your heads worked over you can't run a cam and high ratio rockers at the same time. Clearance issues. If I had my rathers I would go with the cam. Better whole shot with the n*. If I could go back in time I would run Gen5. Go double roller timing chain while your at it.
  4. #4 Re: ...So pulling out the engine & trans
    Mar 2012
    NC
    Quote Originally Posted by krysp432 View Post
    This is the plan.
    SD Headers
    1.9 Rockers
    Spark plug Wires
    CAI
    CAM?
    IC?
    GEN V?
    TIA
    Skip everything and go turbo. You'll make more power.
  5. #5 Re: ...So pulling out the engine & trans
    Buffalo
    Yeah. Fck it - turbo. And fck it - e85. Rinse. Repeat
  6. #6 Re: ...So pulling out the engine & trans
    GT Level Member WolvesSoulZ's Avatar
    Québec
    XP cam has no drivability problems. Even at -40C. Idle speeds are set @ 675 RPM on Park/Neutral and 800 RPM in Gear. Never had any issues.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  7. #7 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    Quote Originally Posted by crazyguy03 View Post
    Yes sir. I have read your review and opinion with this CAM. I am def considering this bad boy.
    Quote Originally Posted by djudge1970 View Post
    I understand that stock rockers are best for a s1x/xp/custom cam. Should i go back with the original rockers that came off or buy a whole new stock set? I guess would have to reconsider upon inspection of original rockers...? Prob be best to replace. I def want to run a GenV, N*
    Quote Originally Posted by Sven The Baldman View Post
    I dont know why, but Turbo scare me! lol
    "IM TURBO MAN!"-in my Arnold voice lol had to do it
    Guess just never had the pleasure of messing with one.
  8. #8 Re: ...So pulling out the engine & trans
    Mar 2012
    NC
    Turbo is honestly the way to go. It's just removing a couple exhaust pieces, bolting on new exhaust pieces, installing the turbo, some injectors, a tune, and then save for a trans because your newly found power will destroy the current one. LOL
  9. #9 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    Yes sir. The trans will be rebuilt or ill buy one ready for my applications. What supporting mods would a turbo require? thanks
  10. #10 Re: ...So pulling out the engine & trans
    Mar 2012
    NC
    You literally could bolt a turbo on a basically stock car and make tons of power. Stock heads and a ST2 cam GMR Badass made well over 300whp in a GTP. I think it was about 350whp but it's been awhile.
  11. #11 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    Wow! Never even considered a trubo...sounds interesting for sure. I'll look it up.
  12. #12 Re: ...So pulling out the engine & trans
    May 2012
    Where winter never ends
    I did an S/C build like yours made OK power but got bored easily so I went turbo. I love it. Current setup is
    Engine:
    T67 Turbo (Precision 6776)
    XP Cam (Going ST5 shortly)
    Stock Bottom End
    Stock Heads ( Heavily ported race heads on the way)
    115# Injectors
    E85
    GFB Boost Controller
    Transmission:
    1in GMR Chain
    1200hp Aermet IS
    Chrome moly input shaft
    TEP Stage 2 rebuild kit
    and a set of MT ET Streets for good measure.
    Pushing around 25 lbs of boost and making around 550 wHP, after i install the heads and cam things will get even more insane.
    Go turbo.
    2000 Regal - Winter Beater
  13. #13 Re: ...So pulling out the engine & trans
    Buffalo
    im demodding my s1x setup next week.... Keep in touch for a great deal
  14. #14 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    Yes sir! Will do.
  15. #15 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    Quote Originally Posted by ADecker View Post
    Engine:
    Stock Bottom End
    115# Injectors
    E85
    Transmission:
    1in GMR Chain
    1200hp Aermet IS
    Go turbo.
    That's really impressive! I'm def going to read a little but more. You're set is awesome. Who did the tranny work?
  16. #16 Re: ...So pulling out the engine & trans
    May 2012
    Me lol
  17. #17 Re: ...So pulling out the engine & trans
    May 2012
    And Triple Edge Performance is where I bought the stage two kit... Best transmission parts available
  18. #18 Re: ...So pulling out the engine & trans
    Sep 2012
    Andrews Tx
    I'll be in contact with them shortly...thanks
  19. #19 Re: ...So pulling out the engine & trans
    May 2012
    Awesome just talk to Dave ... Tell.him your power goals and build ideas and hell build you a transmission
  20. #20 Re: ...So pulling out the engine & trans
    Did the mexicans steal it??
    Because some guy on the truck board that I'm a member of who lives down in houston , his silverado was stolen for 2 weeks. They found it running in a field and it was just trashed on the inside, they were running mexicans in from the boarder. Ripped out the rear seats and everything. Oh and a neat thing about the PK3 keys is that once you start it it will run but if you turn it off and try it again without the key it won't start, so his truck was running for 2 weeks straight and they piled on 7,000 miles in that time.
    Pretty crazy.
  1. Help Pulling Grand Prix GTP Engine and Trans - South Side of Chgo/Beverly - Oak Lawn
    By luckydogaroo in forum Introductions/Noob Questions
    Last Post: 01-22-2015, 01:34 PM
  2. Pulling the engine and/or trans
    By ScreaminZ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2014, 01:03 PM
  3. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  4. pulling trans out of 01 grand prix gt
    By adamtrippin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2010, 11:11 PM
  5. Pulling my engine
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 01:07 PM
