Thread: Loss Of Stoplight Torque
Results 1 to 14 of 14
  1. #1 Loss Of Stoplight Torque
    SE Level Member Konvinced89's Avatar
    Layton, UT
    Hello fellow enthusiasts! I have been having an issue with my car for as far back as I remember. I've owned it for almost 8 years, and it runs pretty well for the most part. Here's the deal: whenever I try to take off fast from a standstill, it seems to have very little torque at first; I can usually only break traction a little if I slam it on top of the painted line. Otherwise, it just slugs up to speed, gaining most of its acceleration around 4500 rpm. Other GTP owners here have no issue breaking traction, so I know it isn't just the 4600 ft altitude. So far, I have have replaced the PCM(Overkill), MAF, MAP, TPS, CPS, FPR,fuel filter, spark plugs(new 104s), and messed around with the boost bypass. I have also tried capping off the line to the boost control solenoid, and removing it to see if its bad. I've made no measurable progress.Again, compared to other 97-03 GTPs with similar bolt-ons, I'm slower in the 1/4 mile. 15.5 was my best on a stock tune and 3.4 pulley, it won't do that on the new tune so I run a modular 3.8. Any ideas as to what the real problem is are welcome. Thanks!
    03 Ivory White GTP: Overkill PCM, MagnaFlow, ubend delete, 3.4/3.8 MPS, AGX/B&G, Buick strut bar, and a big \*/ sticker so they know what just whined by.
  2. #2 Re: Loss Of Stoplight Torque
    May 2008
    Schuyler, NE
    That looks fairly normal to me at your elevation.
  3. #3 Re: Loss Of Stoplight Torque
    Same here.
    Maybe mid 14's with an intercooler and or cam upgrade.
  4. #4 Re: Loss Of Stoplight Torque
    Layton, UT
    It's not so much the acceleration once I'm rolling; I can't spin the wheels on the street under almost any circumstance. My wife's automatic 02 maxima is stock other than a drop-in K&N, and it will spin through most of first gear. I can brake-torque to around 3000 rpm, and the trans still slips enough to keep all traction; does that mean my torque converter is going? 129k miles, all original trans, and I know it's supposed to go soon...😧
  5. #5 Re: Loss Of Stoplight Torque
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    Quote Originally Posted by Konvinced89 View Post
    If it won't spin the tires with the TCS off, then you definitely have a problem. Have you checked fuel pressure or exhaust back-pressure?
  6. #6 Re: Loss Of Stoplight Torque
    Sep 2014
    Worcester, MA
    What cam do you have?
  7. #7 Re: Loss Of Stoplight Torque
    Yeah, lol.
    You've probably got other problems.
  8. #8 Re: Loss Of Stoplight Torque
    Sep 2014
    Worcester, MA
    If you don't have low-end torque, but still pull at 15.5, it sounds like your cam timing is off. Maybe jumped a tooth?
  9. #9 Re: Loss Of Stoplight Torque
    Quote Originally Posted by bobc455 View Post
    I'd find this very hard to believe. If a tooth was skipped, you'd know it. There would plenty more wrong with the car than just a sluggish feeling. You can just toss a cam in these things and go.
    It's something else; like stated.
  10. #10 Re: Loss Of Stoplight Torque
    Buffalo
  11. #11 Re: Loss Of Stoplight Torque
    Buffalo
    In one of my rebuilds , I broke this this part - http://www.transmissionpartsusa.com/...00037766b.htm=
    Which I was told was nearly impossible but I'm not a trans expert and he no longer works for intense. So it's a wash lol
  12. #12 Re: Loss Of Stoplight Torque
    Layton, UT
    Stock cam, and my fuel pressure is about 47 psi with the pump I just put in. Fuel delivery isn't an issue, I have brand new Delco plugs and wires, so I think ignition is fine. I'm pretty sure I'm losing power somewhere between the engine and the wheels, especially the way it only happens off the line. It pulls enough that I'll get wheelspin if I go WOT on a wet road at 45mph, but off the line its just lazy.
  13. #13 Re: Loss Of Stoplight Torque
    Buffalo
    did u look into what i posted?
  14. #14 Re: Loss Of Stoplight Torque
    Layton, UT
    Quote Originally Posted by crazyguy03 View Post
    I did follow the link. It seems plausible.
  1. jerk or shudder sometimes when sitting at stoplight?
    By davidadams in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2014, 07:09 AM
  2. Car Quit Running at Stoplight
    By verlando in forum General Grand Prix Discussion
    Last Post: 02-06-2014, 12:54 AM
  3. GT VS GTP stoplight 2 stoplight
    By 02PrixGT in forum Track Sessions and Kills
    Last Post: 08-01-2010, 03:43 AM
  4. loss of torque any suggestions
    By kyleheine298 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-27-2010, 12:04 AM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
