Thread: Junkyard E85 Injectors
Results 1 to 7 of 7
  1. #1 Junkyard E85 Injectors
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Hey all,
    Just curious if any semi-common vehicles come from the factory with fuel injectors that would be suitable for E85 on our 3800s.
    Not serious about an E85 project at the moment, but I like to keep an eye out for upgrade parts when I go to the junkyard. Injectors are only $6 apiece there, regardless of type.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  2. #2 Re: Junkyard E85 Injectors
    iirc some mustangs amd other fords use "green" top 42# injectors just make your you cut the plugs off the harness side too. id have to check what years use 42s but im about 90% sure some mustangs and other ford v8s use them.
  3. #3 Re: Junkyard E85 Injectors
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I think just the Cobras came with them. GT's did not http://www.moddedmustangs.com/forums...ctor-size.html
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Junkyard E85 Injectors
    GXP Level Member
    Mar 2015
    Tomball
    Only the supercharged ones came with 42's the other's are yellow 19# and I don't remember the color of the 24# in some years.
    Jeff
  5. #5 Re: Junkyard E85 Injectors
    Arizona
    08+gm truck 50 ev6 flex fuel injectors go for 80 bucks new on ebay
  6. #6 Re: Junkyard E85 Injectors
    Arizona
  7. #7 Re: Junkyard E85 Injectors
    Nov 2013
    United States
    Ford Lightnings had 42.5's (good luck finding one in a junkyard).
  1. Junkyard Run
    By Thompsju in forum For Sale - Parts
    Last Post: 10-28-2013, 08:17 PM
  2. anything from junkyard
    By t wizzle17 in forum Wanted To Buy - Parts
    Last Post: 07-28-2013, 08:32 PM
  3. Look what i found at the junkyard
    By shawnschuldt in forum Off Topic Discussion
    Last Post: 08-03-2011, 02:00 PM
  4. Junkyard
    By rocafella2032 in forum Off Topic Discussion
    Last Post: 06-18-2009, 01:27 PM
