Thread: Any help would be appreciated.
Results 1 to 13 of 13
  1. #1 Any help would be appreciated.
    SE Level Member Efrain55's Avatar
    May 2015
    Ok so I have a 1999 grand prix gtp that I've only had for about a month now. The supercharger grinds but doesn't sound like a coupler. I got another charger from my friend for only 60 bucks and I know it's still good as he just did a gen v swap. I just wanted to see of anybody had any tips on how to make this supercharger replacement easier
  2. #2 Re: Any help would be appreciated.
    Jan 2014
    AR
    I would want to confirm that the sound is not coming from an idler or tensioner pulley as a first step. Loosen the belt and see if the S/C pulley wiggles, and spin the other pulleys by hand. Maybe you will find the trouble real easy that way. If not, careful use of a listening stick or mechanic's stethoscope would be next.
  3. #3 Re: Any help would be appreciated.
    i fits only noise at a cold start, thats normal as it goes away when its warmed up. pesky iat sensor
  4. #4 Re: Any help would be appreciated.
    May 2015
    It's there even when it's warm. I know it's the charger. I'm just looking for tips to save myself some time I know somebody has changed one before
  5. #5 Re: Any help would be appreciated.
    its already simple. remove the fuel rail, then the blower.
  6. #6 Re: Any help would be appreciated.
    Nov 2011
    NY
    Post sound sample, and don't be fooled, sound does travel! Coupler sounds like marbles in a can rolling around. Squeaks can be the idler pulleys, etc. Take the SC belt off and idle and see if noise is still there, eliminate the idler/tensioner pulleys. It's a 2 min check off.
    $60 for SC is a sweet deal : )
  7. #7 Re: Any help would be appreciated.
    May 2015
    It sounds like the inside of the charger is grinding
  8. #8 Re: Any help would be appreciated.
    GXP Level Member
    Mar 2015
    Tomball
    These guys have given you all the tools you need to determine if it is the SC or not. Remove the rail then the supercharger. They are all 10mm if I remember correctly. It takes about an hour taking your sweet time.
    Jeff
  9. #9 Re: Any help would be appreciated.
    less then that even. oh, release the fuel pressure in the rail, unplug the injectors, unbolt the rail in the 4 corners, then flip it to the side, then remove the sc bolts. and the belt. dont forget the straight down bolt on the alt side of the snout. its kinda hidden.
    new felpro gasket is 12 bucks at any local parts store. its called a upper plenum gasket. if you ask for a supercharger gasket you'll get nothing.
  10. #10 Re: Any help would be appreciated.
    GXP Level Member
    Mar 2015
    Tomball
    I dont think you get Southern sweet time. ��
  11. #11 Re: Any help would be appreciated.
    May 2015
    I appreciate all the help. I'll most likely be doing it next weekend
  12. #12 Re: Any help would be appreciated.
    Apr 2015
    Columbus, OH
    If you don't know if he's changed the oil in the blower, now would be the time with it off. 16 bucks roughly at my local gm for 2 -4oz bottles. Easier to dump it out then syphon it.
    Top Swapped 01 Imp
  13. #13 Re: Any help would be appreciated.
    taking my time doing my lim gaskets was 3 hours. i spent a hour easy cleaning the gasket from the sc and the lim, worst part of the whole job.
    so if it takes longer then a hour, its due to cleaning off burnt on gasket.
    if you have any height to you, put the car on ramps, it will help your back. hell even if your short ramps may make life easier.
  1. insight appreciated!
    By speed demon in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2013, 01:37 PM
  2. Hello Everyone! HELP would be GREATLY Appreciated!!! Thank You ( :
    By carilyn in forum Introductions/Noob Questions
    Last Post: 04-23-2012, 02:16 PM
  3. Engine hiccup: help appreciated
    By honkbox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 07:05 AM
  4. A little help would be appreciated
    By PITCHBLACKCOMPG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 07:57 PM
  5. Couple of questions and any help is appreciated
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 01-11-2011, 08:00 PM
