Thread: Upper radiator hose sucks in under heavy load
Results 1 to 9 of 9
  1. #1 Upper radiator hose sucks in under heavy load
    Apr 2015
    Burtonsville, Maryland
    this is a big problem as it is constricting coolant flow from the upper radiator to the thermostat housing . My question is what could be causing this? surely someone here has had this issue. thank you for any input . my car is a 97 regal GS
  2. #2 Re: Upper radiator hose sucks in under heavy load
    GXP Level Member
    Mar 2015
    Tomball
    Your thermostat is stuck closed.
    Coolant flow is from the lower radiator hose to the water pump through the engine, out the thermostat and upper radiator hose to the radiator to be cooled and recirculated. The lower hose usually is reinforced so that it doesn't get sucked close under high demand and the restriction of the radiator. The upper on the other hand is not since it will always be under higher pressure. Because the thermostat is stuck shut, or is not opening properly, your pump is pulling all it can and it's flowing through the engine and the highest restriction and therefore low pressure area now becomes the outlet of the thermostat. And that is why it gets sucked closed.
    Jeff
  3. #3 Re: Upper radiator hose sucks in under heavy load
    Apr 2015
    Ok l I had ordered a new one anyways. ill install it and report back thank you for a quick and direct response .
  4. #4 Re: Upper radiator hose sucks in under heavy load
    Apr 2015
    Ok the thermostat fixed the issue. I found another source of a potential issue. The PO had installed one of those stupid vent radiator caps. The cap was preventing the cooling system form building pressure . This is likely what caused the old thermostat to age prematurely. Luckily I caught it before any real damage was done .
  5. #5 Re: Upper radiator hose sucks in under heavy load
    the caps let coolant out after 16 psi, then suck the coolant back in as the car cools. so its kinda normal if thats what you mean by vented.
    its why you have a over flow tank.
  6. #6 Re: Upper radiator hose sucks in under heavy load
    Apr 2015
    the old radiator cap was defective. the cap was preventing the system from building any pressure at all
  7. #7 Re: Upper radiator hose sucks in under heavy load
    then the over flow tank would have been over flowing.
    caps do wear out, the spring goes bad, or the rubber seal fails.
  8. #8 Re: Upper radiator hose sucks in under heavy load
    Apr 2015
    it wasn't overflowing at all which is strange . All I know is it seems to be much happier now and staying between 180 and 190
  9. #9 Re: Upper radiator hose sucks in under heavy load
    GXP Level Member
    Mar 2015
    Tomball
    I've never had a rad cap that was weak not cause an overflow, especially since I live in southeast Texas where the temps get into the high 90's at night.
    Make me sure you get the thing bled out properly, take it for a spirited drive around the block with a couple of full throttle romps through 2nd at least then park it and allow it to cool overnight then top off the overflow. Check it for the next few days. There are bleeder screws as well but I'm sure you already did that.
    Jeff
  1. Heavy Isolated Misfire Under Load
    By Jomamma in forum General Tech Discussion
    Last Post: 11-15-2014, 02:20 AM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. upper raditor hose
    By kenconerly in forum General Grand Prix Discussion
    Last Post: 02-17-2013, 10:22 PM
  4. Horrible misfire under heavy load: P0300, and P0171
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2010, 06:28 PM
