Thread: Misfire on 2&4
Results 1 to 17 of 17
  1. #1 Misfire on 2&4
    SE Level Member 98DaytonaGTP's Avatar
    May 2015
    United States
    I don't mean to double post something on a misfire just seems like a different problem. So my 98 gtp is misfiring on 2 & 4, now I have replaced the plug wires spark plugs, Icm, swapped the coils packs, even moved # 2&4 injectors to 1 & 3 to see if it was causing the misfire but it still keeps showing up at 2 & 4.... Any ideas?
  2. #2 Re: Misfire on 2&4
    Are you positive the wires are on the right plugs ?
  3. #3 Re: Misfire on 2&4
    May 2015
    United States
    Yea I've checked I don't know how many times
  4. #4 Re: Misfire on 2&4
    Since it's two different coils, that is very odd. It's much easier (been there..done that) to swap up the wires in error since you can't get great visibility back there.
  5. #5 Re: Misfire on 2&4
    Top of coils to the bottom.
    2 4 6
    1 3 5
    Standing at the front of the engine.
  6. #6 Re: Misfire on 2&4
    May 2015
    United States
    I also did change plug wires and it's still there I'm thinking plugs next
  7. #7 Re: Misfire on 2&4
    May 2015
    United States
    Yeah the placement of the coils and the firing order is right... What a pain
  8. #8 Re: Misfire on 2&4
    St. Louis
    What brand/type of spark plug did you install?
  9. #9 Re: Misfire on 2&4
    May 2015
    United States
    NGK-R TR6 V Power
  10. #10 Re: Misfire on 2&4
    May 2015
    United States
    NGK-R TR6 V Power
  11. #11 Re: Misfire on 2&4
    St. Louis
    Is your GTP completely stock? As in, not dropped a pulley size? Do you always run premium fuel?
    Not sure if you've read the "safely modding your 3800" thread, but maybe this will help.
    4) Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture:http://i33.photobucket.com/albums/d6.../plugwires.jpg
    AC Delco Factory Replacements: Stock
    Autolite 606: Stock
    Autolite 605: 1 Heat Range Cooler
    NGK TR55: 1 Heat Range Cooler
    Autolite 104: 2 Heat Ranges Cooler
    NGK TR6: 2 Heat Ranges Cooler
    Autolite 103: 3 Heat Ranges Cooler
  12. #12 Re: Misfire on 2&4
    May 2015
    United States
    Stock pulley, and cold air intake. Nothing else and I do run premium fuel
  13. #13 Misfire on 2&4
    Mercer, Pa
    How are you reading the misfires? Scan Gauge, DTC codes.
    Misfire at idle (vacuum)
    Misfire under boost (pressure)
  14. #14 Re: Misfire on 2&4
    May 2015
    United States
    Mainly vaccum and very low boost p0300 code on 2&4
  15. #15 Re: Misfire on 2&4
    Enfield, CT
    Try cleaning the contacts on the ICM
    Sent from my LG G3
  16. #16 Re: Misfire on 2&4
    Apr 2015
    Columbus, OH
    P0300 is a code for random misfire. Not sure how you would deduce that its 2 and 4. How did your coil packs fit on the ICM? Do they pull off and on real easily?
    I had random misfires. Went ahead and replaced the stock coil packs on my 133k mile car. New ones took a good amount of force to push on the ICM prongs. Very tight fit. Old ones I could just drop on. So far it was the best mod I've done to my car! Under 70 for all 3 coil packs. If you have high mileage I'd recommend just replacing them as a maintenance thing anyways.
    Only replace with OE ac delco cp's.
    Edit: I may have misread your reply. I see now you probably meant a 300 code for misfire on 2 and 4. Gotcha.
    Top Swapped 01 Imp
  17. #17 Re: Misfire on 2&4
    May 2015
    United States
    Yea the coil packs just slide right on. And I have a scan tool that tells me which cylinders are misfiring
  1. misfire??
    By NewBoost1997 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2012, 12:49 PM
  2. Misfire #6
    By rnpiii in forum General Tech Discussion
    Last Post: 08-03-2012, 01:56 PM
  3. 04 GTP misfire..a fun one..
    By silly34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2011, 11:42 AM
  4. 97 se misfire...please help
    By dei8fn in forum General Tech Discussion
    Last Post: 06-27-2010, 04:33 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
