Thread: She wont go!
Results 1 to 7 of 7
  1. #1 She wont go!
    Sep 2011
    Mahanoy City PA
    I just put my 2001 GTP back on the road. It was sitting for 2 years. Ran perfect when parked. The problem I have now is it won't accelerate without serious bucking. The gas is fresh, no check engine light or any other light is on. Runs fine at idle and low speeds. As soon as I try to go up a hill or pick up speed, it carries on like there is a bad plug or wire. Everything is brand new. Any help or advice would be appreciated.
  2. #2 Re: She wont go!
    St. Louis
    You got the plug wires in the right order?
  3. #3 Re: She wont go!
    Dec 2012
    Where 4T65E's were born
    Check the plug wires and coil packs, make sure the wires aren't arcing to anything. Same with the coil packs. I like taking a test light, hook the wire to ground, and with the probe, rub it against the wires and coil packs while running. Don't pierce the wires obviously. If a spark jumps from anywhere, there's a problem.
    Sold.
  4. #4 Re: She wont go!
    Feb 2013
    37.295091, -121.930053
    this is so you dont mess it up
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: She wont go!
    HUDSON
    Check your fuel filter. A clogged fuel filter will restrict the fuel, and the bucking you feel during acceleration is the engine going lean.
  6. #6 Re: She wont go!
    Dec 2012
    Also check for a cracked plug while you check out the wires and coil packs. A crack in the porcelain will often cause misfires only under load.
    Sold.
  7. #7 Re: She wont go!
    SE Level Member velocitytech's Avatar
    Apr 2015
    MartinsFerry,OH
    Ive kinda had the same sitation before. Complete dead spots in the throttle. It gave the weirdest Problematic issues. Turned out to be faulty plugs that had less than 2k.
    Good luck
  1. Topped swapped 06 GP now wont start and scan tool wont comm with ECM
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-31-2013, 08:36 AM
  2. a/c wont work and heat wont go to floor PLEASE HELP!!
    By Brett Muszynski in forum Introductions/Noob Questions
    Last Post: 02-10-2012, 05:43 AM
  3. Need help ( car wont run)
    By OrangeL67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2011, 02:22 PM
  4. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  5. You wont believe this...
    By IR II IP IDEATH in forum Track Sessions and Kills
    Last Post: 03-16-2010, 12:09 AM
